Old 12-14-2020, 11:09 AM
Bill Eveland's Avatar
In higher hp levels I would switch to the big bearing new style 9" ends and keep the original disc brakes instead of c clip eliminators which I don't believe they even make for an explorer rear end. . But anyway they work good on my Dana 60. All else that's needed are the spacer rings for the thickness of the backing plate.
Originally Posted by ScottK. View Post
Just my 2 cents but why not pull a Ford 8.8 out of a Ford Explorer they are every bit as strong and some would argue stronger than a GM 12 bolt and disc brakes are free.You can pick these up for under $200 and there everywhere.All you have to do is cut the long side axle tube out of another donor I paid $25.00 for the extra tube and don’t forget to grab the long side axle as well.There is only a 1/2 inch difference (longer) on each side.Just throwing this out there but there well known to handle 1000 horsepower people do it all the time.
Illinois Outlaw Gassers
6.27@107
9.97@131
