Old 12-21-2020, 04:47 PM
mysticmissle's Avatar
Didn't you buy a blem IA2? you obviously are willing to take a risk with a few thousand dollars.
I think my china heads came today. I do not expect them to live forever, but I do think they will be a fun set to try and make a cheap turbo build. No earth shattering power, but im going to try and piece together a budget set up. <6K that's what these heads are budget. As long as you accept that going in, and their possible failure, it is the race section, there are no suprises
I can name people with just about every aftermarket head, that has had seat issues. these heads look like they have better machining than any of the other offerings, only time will tell of their longevity
Old 12-22-2020, 11:35 PM
blueghoast's Avatar
I've bought two sets of Speed master heads and I'm Impressed with
there quality and componets, They more then exceed edelbrock heads.JMO
GT.
Old 12-23-2020, 06:39 AM
Murf Murf is offline
Originally Posted by pontiac6269 View Post
These are the head bolts I bought. ARP 190-3605, this is what they list in the description of the heads on the speedmaster site.
Thanks man! I must of missed it on their site.
Merry Christmas!
Murf
Sent from my iPhone using Tapatalk Pro
Old 12-25-2020, 01:04 PM
pontiac6269's Avatar
pontiac6269 pontiac6269 is offline
I was looking mine over again and discovered one of the helicoil inserts was missing for one of the rocker arm studs. Have to order rocker arm studs, all ready have head, intake and exhuast gaskets. Going to take apart and blend the intake port entrances. Want to test my car with the Torquer 2 next spring and then swap the heads to see how much of a difference they make compared to my 670s.
Eric
1969 GTO - 461, turbo 400, Continental 13", 3.08 gears. - 12.59 e.t. @ 108.43 mph, 1.898 60'
1978 Oldsmobile Cutlass Supreme- 461, turbo 350, PTC 3500 converter, 9" 3:50 gears. = 11.39 e.t. @ 117.55 mph, 1.599 60' on E85
Old 12-25-2020, 01:36 PM
Has anyone figure out what the stock hr springs will
Work with for a cam?
Old 12-25-2020, 01:43 PM
dragracerx2813's Avatar
dragracerx2813 dragracerx2813 is offline
I have to change the springs to work with my SFT . But it would be interesting to see what the quality of the springs are.
Old 12-25-2020, 07:26 PM
68hotbird 68hotbird is offline
Default 2.19 intake valves 1.77 exhaust valve job complete
I finished up the 2.19/1.77 valve upgrade in these heads. Cut the bowls, have a little more hand work to do to finish up port work but coming along nicely.
ID:	556871   Click image for larger version
ID:	556872   Click image for larger version
ID:	556873   Click image for larger version
Old 12-25-2020, 07:50 PM
tempest1964's Avatar
Care to guess what they might flow? All I can guess is ‘pretty dang good’
Old 12-25-2020, 08:20 PM
There are some sharp thin areas I would smooth out if you spray it. I have a set to
Old 12-25-2020, 08:25 PM
Default flow and finish work
I have not finished the smoothing of the port yet these were just off the Serdi machine I have a couple more hours of sanding roll work to finish. I think they will flow 315-320 at .600 which should be great for the street 461 they are going on.
