You try to make a point in the video about high lift cams. As I and others have tried to point out in the various threads about this subject, with a properly designed cam, the high point of the lifter travel is independent of the cam lift. It is the lifter drop that varies with the cam lift. The nose of any properly designed cam will be just a few thousandths below the journal radius. THe base circle of a high lift cam is smaller, so if you want to make a point about high lift cams you should show how much of the lifter flat is above your plate when on the base circle. |
https://www.facebook.com/randy.repp....20571751861803
Randy Repp 1964 GTO "GoatZilla" 1964 GTO "Injunuity" A/FX Nostalgia Super Stock 220" Rear Engine Pontiac Powered Dragster https://www.facebook.com/PontiacSpeedShop/ https://www.facebook.com/GoatZillaRacing/ https://www.facebook.com/groups/RebuildExcitement/ https://www.facebook.com/Call1844RacersRV/ https://www.facebook.com/groups/INJUNWARS/ |
