Closed Thread
Old 02-26-2021, 10:14 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
My front cylinders get more air from the blower, so I run bigger fuel nozzles in the front cylinders than the back ones. I fine tune by EGT (have a sensor on every cylinder). I balance the temps by cyinder and that's my final tune. My hat nozzles are all the same, but my port nozzles run bigger in the front, since the opening on the bottom of the blower is offset to the front. It's not a big difference between cylinders, though.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 02-28-2021, 11:10 AM
GTOGEORGE's Avatar
Jim
Problem is I don’t have that luxury, I’ll just have to jet the snot out the carbs and hope for the best. I have 210’s in them now......I have jets up to 224’s. This will be fun! PPTTF!
GTO George
Old 02-28-2021, 01:09 PM
misterp266's Avatar
Used to hang out with a Nostalgia nitro F/C when I was at the March Meet that actually ran different pistons front to back to make up for the compression difference. I think they were surprised that I noticed. Lots of tricks to getting all eight making power.
Good luck George!
" Darksiders Rule "
Old 02-28-2021, 06:35 PM
GTOGEORGE's Avatar
Good luck George!
I love going to the nostalgia races!
All I can hope for is richer up the lean cylinders and hope the rest aren’t too fat, luckily I run low boost.
GTO George b
Old 02-28-2021, 08:52 PM
Being rich with alcohol is no problem.
Being just a little lean can be very expensive, especially with a blower.
Better to err on it being rich.
Old 03-01-2021, 01:46 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
... My front cylinders get more air from the blower, so I run bigger fuel nozzles in the front cylinders than the back ones...
My 6-71 blown M/T hemi V8 was especially bad in that respect, since the equally-spaced intake ports caused #7 & #8 to be much further back than a normal Pontiac. I improved the airflow distribution- not a lot, but significantly- by swapping the rotors side-for-side, to tend to "blow" toward the rear instead of the front.
Old 03-01-2021, 11:50 AM
GTOGEORGE's Avatar
The Blower Shop mentioned that to me.
GTO George
Closed Thread
