Old 03-13-2021, 11:36 AM
jhein's Avatar
jhein jhein is offline
Hello Unruhjonny. Yeah, I know it's the shifter lever. I was just being lazy, trying to avoid the extra keystrokes (like I'm doing now, LOL!!). I'm not a very good typist, or keyboarder as the case may be so I try to keep it to a minimum. I thought it would be OK since it was not a technical discussion of the part, just the appearance. So, sorry if that wasn't clear.
As for the differences between the levers, the 7945 looks to be shorter to me, compared to the 7244. Also, because of the bent shaft, the 7244 extends back further towards the driver so it has a "longer" reach back than the 7945. Of course, that is accentuated by the different knob, but even if you measure to the base of the knob, it still goes further back. Anyway, that's what I see. Maybe it's just the photos.
FWIW, I'm an average size person and I find the 7945 very comfortable to reach.
Shift on!!
  #42
Old 03-14-2021, 12:11 AM
unruhjonny's Avatar
Ok, I was just trying to help clarify what read to me as a misunderstanding of sorts.
I hope you thouroughly enjoy your TA
1970 Formula 400
  #43
Old 03-14-2021, 01:14 AM
jhein's Avatar
I get it. These cars, this hobby, are all about specifics. Maybe I was a bit sloppy in my comments. Hopefully no harm.
  #44
Old 03-21-2021, 01:54 AM
KS circutguy's Avatar
275 60 15's rear I think I used 235 60 15 frt. if you like
Leave everything as is and add a Gear vendors under overdrive. imo
https://www.gearvendors.com/hrgm4sm.html
Nice ride.
  #45
Old 03-21-2021, 09:54 AM
unruhjonny's Avatar
I love the look on reproduction period correct white letter tires, but in years bygone I did ply with different sized BFG radial tires;
I believe that the actual radial size for our cars was 225/70r15 - (which I believe is an F-70-15);
I found that 235/60r15 was about perfect (and it should be, it's the reccomended size), but it also seemed a smidge small;
I went next to 255/60r15's and found that mounted on 15x7" wheels they would baloon and wear from the center of the tread out;
My opinion is the best modern radial size I found was 245/60r15, it's just a bit wider than the 235, it ever so slightly fills the wheel wells better than the 235, and there was no balooning effect.
I also like the same width and profile on 14x7" wheels.
1970 Formula 400
  #46
Old 03-21-2021, 10:41 AM
jhein's Avatar
I thought about the overdrive. Still considering all options but leaning heavily towards a 3.08. I know many will consider that sacrilege, but they did offer a 3.08 that year, just not with a 4 spd. Regardless, I need something for more comfortable cruising. And it's something easy to correct in the future if anyone wants to.
I do like the period correct look of the Polysteel tires. They look great from the side, but too skinny otherwise. I'll probably go with the BFG's eventually. Probably the 245/60. Although, if I went with 15x8 rear wheels, then I could put 255s on the rear, hmm...
  #47
Old 03-25-2021, 06:39 AM
455firebird1969's Avatar
Congrats, that is my dream car, and yours is beautiful.
  #48
Old 03-25-2021, 11:06 AM
Gator67's Avatar
Gator67 Gator67 is offline
I had 3.31 in an M20 (400) car and I thought that was a good compromise.
The Following User Says Thank You to Gator67 For This Useful Post:
