#161
Okay, the tank was removed and repainted, The new sending unit was installed and the tank was reinstalled with new attaching hardware.
The wires have all been re-attached and the fuel gauge works as good as new. A big Thanks to everyone that provided tips and advice. |
#162
Greg
Thanks for your input to the Forum. Help please with fuel gage pegged on F. '64 GTO. What next steps? Using volt ohm meter: 1. Key on, 11v on tan wire unplugged and grounded to ground point near tank As above, gage needle is past F. Switching key off needle moves down from peg slightly and back to peg switch on 2. Key on sending unit terminal grounded and needle pegs F 3. Sending unit terminal to ground 74 ohm. Tank is down a little from full 4. Unplugged tan wire to ground 45 ohm. I have spare gage pn 6430125 I think is 1965 so 90 ohm. Across the wire wound resistor between the two blades 40 ohm. Left blade to ground stud 90 ohm. Right blade to ground 130 ohm. |
#163
What year gauge is in the car right now, a 64, zero to 31 Ohms (range span) or a 65 gauge (zero to 90) ohms range span? Did you test the sender before you put it in the tank? ALL senders should be tested prior to install, it is almost certain that the makers of new reproduction parts do not bother to test their senders prior to shipping.
Your test #1 does not seem right to me. Could you post photos of the front at the back of the gauge? Also that gauge needs ground at the silver steel plate which is the access hatch at the back of the gauge. Without a "reference ground" at the dash the gauge will never work!!! I would like to see how this is wired. Any GM dash gauge for Fuel, temp or oil pressure absorbs voltage so the input voltage (measured) would be at least 11 volts; more in the range of 12 or 13 if the engine is running but the output voltage from the tan wire back to the sender would be no more 3 or 3.5 volts. Especially with a fuel gauge; you would NEVER EVER run 11 volts into a fuel tank sender. A) that could burn the resistor card & damage the sender and B) If that were to ever spark across the resistor card via the copper touch tab and there was almost no fuel in the tank the resulting spark could very well ignite the vapors inside of that tank, which would be VERY BAD !!!
Peter Serio Owner, Precision Pontiac |
| The Following User Says Thank You to Peter Serio For This Useful Post: | ||
#164
There's the guy that can answer all your questions way better than I can ^^^
Greg Reid Palmetto, Georgia |
#165
Peter,
I disconnected the rear harness to take the sending unit out of circuit. Switch on, I have 12 v to ground on tan wire at the fuse box side of harness connector. Pulled dash forward enough to access fuel gage. Compared what I saw to photo of gage connections. Homer Simpson "Doh!" Reversed leads to correct terminals and gage reads correctly now. Thanks for your comments. |
#166
"DOH"..........LOL
#167
I had same problem years ago on corroded push nut connection on the sending unit. I just cleaned and soldered it together. Doesn't take that much heat and if you use a little flux it will stick to it. You can throw that push nut away.
Also want to point out that these cars being 40 - 50 years old any connections that are plugged together are prone to corrosion. Any corrosion will cause resistance, voltage loss, heat and only get worst until complete failure. When cleaning to bare metal for grounds a little electrical grease will keep it from re-corroding. Push connectors should be pulled apart, wire brushed, scrape corrosion out, cleaned with electrical contact cleaner, use a dab of electrical grease to prevent corrosion and pushed together. Easier to take apart next time but there shouldn't be a next time! I just went through low blower speed, smoke, no blower due to corroded contacts in ignition switch. New switch, all heater blower contacts cleaned and greased. I was surprised at how corroded every contact was and car sits in heated garage! But I guess gm didn't have time to grease every plug connector while putting it together 45 years ago. Now the blower works full speed.
| The Following User Says Thank You to 69Customs For This Useful Post: | ||
