Old 03-26-2021, 06:46 PM
Default What did you do to your Pontiac Lately?
I have been searching for a set of Street Edition wheels for my 2009 Solstice coupe for about a year now. Got lucky and found a set. Those and the blacked out headlights complete the outside of my 1 of none Street Edition coupe
1st picture is the original non polished 2009 wheels, the 2nd is the Street Edition Wheels mounted. 3rd Picture is the original chrome headlights, 4th is with the Blackened headlights used on the Street Edition and Turbo Coupes only.
Lets see what every one has been up to lately!
Name:	Original wheels.jpg
ID:	563427   Click image for larger version
ID:	563428   Click image for larger version
ID:	563429   Click image for larger version
Old 03-26-2021, 07:18 PM
jerry455 jerry455 is offline
Beautiful car Jeff. They should have made more of the hardtops.
Old 03-26-2021, 07:28 PM
GT182's Avatar
GT182 GT182 is offline
Now that's one to hang on to for a long time. Instant collector's car. Looks sweet, but how in hell do you see out of it.
I've only seen one, in grey, that's in this area, and plated for Delaware. Right in the area of it's birth place. The GM plant is gone and in it's place.... a freekin Amazon warehouse that takes up more room than the GM plant did. It even covers where the Anchor Mtr Frt terminal and garage was, and the loading area to get them out to the dealers.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 03-26-2021, 09:46 PM
tooski tooski is offline
Put second gen door mirrors on my 68, installed driver's door hinge pin bushings & detent plate, installed drive shaft safety loop, rebuilt Quadrajet per Cliff's kit & recipe (testing & adjustments, if needed, in better weather).
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
Old 03-26-2021, 09:48 PM
OG68 OG68 is offline
You must have some really long days up North lol.
Old 03-26-2021, 10:35 PM
moneypit's Avatar
moneypit moneypit is offline
New engine in the 37. Getting close, just need to wire up the new fan controller and put the front end back on. Hopefully this weekend!
ID:	563447   Click image for larger version
ID:	563449   Click image for larger version
37 Pontiac Sedan 455 700r4
94 Firehawk Supercharged 5.7 LT1 6spd.
71 GTO base 400 A/T
97 F250 7.3 turbo diesel
The Following User Says Thank You to moneypit For This Useful Post:
Old 03-26-2021, 11:10 PM
Jonsie Jonsie is offline
Man, aint that the truth..........................
Old 03-27-2021, 12:32 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Which Pontiac?
My '59 GMC/Pontiac came out of storage, got a set of air shocks with onboard pump/controller, and a new pinion seal on the Posi rear end.
Crossed a few things off the list for the Pontiac powered lakester.
Replaced the alternator belt on the Wangers' Bandit Suburban.
Old 03-27-2021, 01:04 AM
Lemans64's Avatar
Lemans64 Lemans64 is offline
Did manage to get mine fired up for the 1st time this year. Not out of the garage yet though, close. Did get my one of my LED tail lights fixed.
Have some other stuff to install yet, Global west Bump steer arms, and a New proforged center link. Then will do another alignment, Have a new machine at
work to try out on the Lemans. Also have a new turn signal switch that needs to get installed, have had it for a few years, LOL. Old one does not cancel all the time and
then the left brake light does not work when I forget to make sure it got centered. Hopefully get her out on the road soon.
Weather is starting to warm up and have seen a few rides out already.
64 Lemans hardtop
4spd, buckets
Old 03-27-2021, 01:22 AM
Chris65LeMans's Avatar
Finally got my brakes put back together after quite an ordeal. Then discovered I had zero compression in cylinders 2 and 4. Off for rebuilding go the heads.
Old 03-27-2021, 01:26 AM
Drag Star Le Mans's Avatar
Rowed the gears in my 73 Formula 400 4spd. Smoked the tires the 69 GTO. Sold the 63 LeMans and nearly sold nearly sold my 544127 SD heads. Good times!
DragStarLeMans
The Following User Says Thank You to Drag Star Le Mans For This Useful Post:
Old 03-27-2021, 07:30 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
New plugs and air filter and drove to the track for the first time this year. Got my best 60', et, & mph but not all on the same run. Great day!
ID:	563465   Click image for larger version
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
Old 03-27-2021, 12:00 PM
Glad to see some of us are getting back on the road, money pit that looks like it is going to be quite the ride when its done!
Jack, you are like me to many projects going at once!
I also swapped out the worn cloth seats for a set of decent black leather seats a couple of weeks ago on the coupe
Name:	Drivers seat changed.jpg
Old 03-27-2021, 01:30 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
Mine are in storage waiting for some work to get done and then transported to my new house. Very very slow progress due to medical issues.
Old 03-27-2021, 01:53 PM
66beaumont's Avatar
66beaumont 66beaumont is offline
Have my motor ready to pull. Dropped out the th400 and currently fitting the new TKX. Once I know it clears tunnel will pull engine for a clean up and replace leaking oil pan. Looks like tunnel will need a little hammer work only and tranny should fit nicely
69 gto ,all#match,467,th400,3:55 Easton posi,resto completed may 2016. 427 hp/530tq. Stump puller with stock#62 , stock intake and qjet
Th400 gone. Tkx close ratio with .64 of
66 Pontiac Beaumont sport deluxe,BB 5sp tko 3:08 auburn 450hp 550 torque wife sold it
Old 03-27-2021, 05:00 PM
Adding power locks to my 76 Firebird. Just finished my RetroSound stereo and speaker installation. Sounds awesome.
Old 03-27-2021, 05:04 PM
geeteeohguy's Avatar
Cleaned and adjusted the driver's side window regulator that I had mistakenly lubed with white lith grease years ago and it was locked up. Works fine now. Took it out on errands today and banged some gears. I've had this one for 39 years and never get tired of it.
Jeff
Jeff Hamlin's Avatar
Thumbs up
Keeping it in working order and driving it every chance I get...
Today was some of the first steps back to NORMAL and friggen long overdue!!
Old 03-27-2021, 05:29 PM
JLBIII JLBIII is offline
Pulled alternator to have new bearings put in, replaced fuel pump, fixed choke. Have a new set of rear leaf springs and sub-frame connectors ready to go in.
Old 03-27-2021, 06:03 PM
1_Wild_Cat's Avatar
Still having the metal finishing done to bring the body into shape...Ordered 4-gallons sprayable of epoxy primer. Hoping to get the epoxy on the metal as soon as temperatures allow.
The Following User Says Thank You to 1_Wild_Cat For This Useful Post:
