Little bit of an update, I have the car on the road and driven it about 50 miles so far and I'm impressed with the way it shifts the gear spread seems to be great with my 3.23 rear gears. Only down side so far is I have a pretty good vibration at 70MPH and above, jacked the car up on some chalks to load the suspension today and had a better look at the pinion angle which didn't seem to be an issue with the Muncie but I was pretty hard pressed to go over 60 mph for the most part due to traffic etc. I found the trans output is -4° and the pinion yoke was basically 0° so I have adjusted the rear upper control arms to get the pinion angle at +3 and will test drive it tomorrow and see how it is. I'm thinking my lower profile energy suspension trans mount may be part of the reason for the -4° but I was unable to shim the trans any higher as it was close to hitting the shifter porch.
I mentioned below also about the cross member. I mistakenly said that the rear bolt hole for the rubber insulator will become the front hole for the new trans this is not correct. I had a factory hole just aft of the original front mount location this was used as the new front mount hole and the rear hole needed to be drilled on each side.
65 LeMANS , SD performance 462ci Engine, Tremec TKX 5 speed with a 3.73 geared 8.5" 10 bolt |
![]() You're going to have a lot of happy cruising this summer. |
I think if you are down -4* at the trans you will want the front of the pinion UP the same amount (-4*) minus a couple degrees to compensate for the pinion rotating up during acceleration. So if you are down -4* at the trans you want the front of the pinion UP roughly -2* Hope this makes sense, this topic can get pretty confusing lol
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55 '72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80 |
This is all good information for me: I hope to hear an update after your test drive today!
| The Following User Says Thank You to Guido For This Useful Post: | ||
well took it out and hammered on it today up to about 90 mph on what I will call a closed course..... Vibration was much better. Tomorrow I'm going to fine tune it some. I came up with -4 at the trans and finished with -3 at the pinion, Today I remeasured with a better digital protractor and it's more like -4.3 and the pinion -2.4 so still room for improvement.
| The Following 2 Users Say Thank You to TB1 For This Useful Post: | ||
Another thought about the vibration, if you haven’t already, maybe consider having the driveshaft balanced? I had a similar vibration in my’67 wagon and that cleared it up. Sent from my iPhone using Tapatalk |
The driveshaft was shortened and balanced with the new yoke after I measured once the trans was installed. weights are all still intact. Going to test drive later today and see how it goes.
