Old 06-13-2021, 09:49 AM
slowbird's Avatar
slowbird slowbird is offline
If you want a comparison a local customer here built a 400 with ported #62's. I had him use the Crower 60243 cam with high ratio rockers and Rhoads lifters. It's topped with a STOCK cast iron intake and 1968 Pontiac Q-jet. I built his TH350 and supplied a custom torque converter for it, 3.73's out back. In street trim his Firebird on DOT's it runs into the 11's! Do the math on that at 3600lbs race weight as see if that cam makes just a little bit more power than the XE262 or 268 in the same build?.......FWIW........Cliff
Our 406 with xe274 can did that which seems to me is closer to an apples to apples comparison vs the 262 or 268 cam
