#381
I have the 4 cylinder, let me know the city and zip where you live.
#382
Message sent. I found all of the distributor internals just need the front bumper and air cleaner stuff as well as the headlight trim rings.
#383
Anyone have 61-62 hood springs or spring they will part with? Thanks Rod
#384
Have a set of 63 hood hinges with springs?
#385
Mine are approx 7 inches long and 1 3/8 around. Are the 63 that size and how much. Thanks Rod
#386
Outside trim for a 63 Lemans sport coupe gasket style windshield
#387
Hello. I'm looking for a pinion bearing retainer (part # 542406) and pinion bearing (part # 7450984) for a 62 with 3 speed manual. Thanks!
#388
Looking for a stock 4 row Harrison radiator for my 63 Lemans. Part number is 3158857. Thanks!
#389
Looking for a 2-barrel or 4-barrel intake for a 4-cylinder 1962 Pontiac tempest.
Also looking for a 4-speed transaxle, need everything from the bell-housing back. Also need a front and rear suspension bushing kit. Are these available anywhere? |
#390
They did not make a 2bbl 4cyc intake.1bbl and 4 bbl.Tom
#391
Kanter has the front, Ames has the rear
#392
Looking for a new or like new pitman arm for a manual steering 62 Lemans
Wayne 918-697-6965
Pump gas and hydraulic cams are for minivans..... ![]() www.smotherssupercars.com Check out my Performance Engine Building and Carburetor Tuning DVD......... |
#393
These are sometimes on ebay but for the most part hard to come by.
Several good places, amesperf.com or rareparts.com Note that rareparts.com will rebuild your existing one. You box it up and ship to them, they rebuild and send it back in about 10 days. |
#394
Looking for a V8 cross member
Sent from my SM-G998U using Tapatalk |
#395
Looking for a 4bbl intake manifold (4cyl)
Also Looking for power brake booster and bracket 1963 tempest convertible |
#396
1963 Tempest or Lemans. I need both the upper and lower section of the front end. Also the pot metal outer trim pieces. Little rust or dents ok, but needs to be overall solid. Do not need the headlamp buckets, lights, emblem or grills. Need asap.
#397
I have one side of the pot metal part that goes on outside of headlight (sometimes called eye brow). $35 + shipping
#398
I found the front end thanks everyone.
#399
WTB Stainless windshield trim for gasket style window. 63 sport coupe.
#400
Need a passenger side door window channel for a 62 Tempest lemans 2 door sport coupe. Mine is rusted out.
