I got the driveshaft painted with epoxy primer and installed:
![]() ![]() ![]() ![]() I installed the Lokar throttle valve cable. I used a length of heat shrink tubing on it in the area where it is near the spark plug wires. ![]() This Lokar throttle bracket is made specifically for the Edelbrock Pro-Flo 4 and is perfect. It has a provisions for the TV cable, throttle cable and a cruise control. I got the TV cable adjusted and it was pretty easy to do with this setup. ![]() I got the RobbMc mini starter installed. I really like this starter. It was so easy to install because it is so small and so light. Very simple to rotate the solenoid anywhere you want it too. No shims were necessary. The lash is .016" and gear clearance when disengaged is 1/8". All kinds of room vs a stock starter:
'69 GTO Convertible - Acquired October 2020. An all original project car. Restomod is underway PROJECT THREAD '83 Chevy Choo Choo SS El Camino - LT1 350/4L60e, Owned for 30 Years, completed 2nd restomod in 2018 PHOTO 2019 BMW 440ix - Twin turbo I6, 8spd auto. PHOTO '55 Chevy Bel Air Sport Coupe - Ram Jet 350 / T56 Magnum 6spd, Restomod Completed Sept. 2012, Sold Sept. 2021 PHOTO |
That starter does look nice! Looks like you can reach the oil pan bolts and the drain plug on the side of the block without removing it.
