Just got this Ram V 303 together for my 69 Firebird, supposed to be Buck Baker`s old race engine but don`t have anything to document it.
| The Following 2 Users Say Thank You to Aluminum Chief For This Useful Post: | ||
Did it come with the fuel injection ?
What I remember was those heads did not flow until you got to a silly RPM and then would wind to the moon. |
What fuel injection?
Most of V dope is bad dope.JMO,Tom
I think he's saying that a lot of RAV information is bad information - there's a lot of legends floating around out there, and not very many hard facts. I think Tom has as much hands-on experience with them as anyone, so he can probably say that with some authority.
Wow! How rare is that! Are you going to dyno it before you install it in the car? I'd be curious as to how it runs.
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
| The Following User Says Thank You to Gary H For This Useful Post: | ||
No I don`t plan on a dyno test.
I'll bet the hardest original factory part to find for your build was that 406 coil.
You know it! The coil with Bracket and the exhaust manifolds which I haven`t installed yet.
See pic also has FOO5417-12 inscribed on it.
Just a side note but with solid state ignitions beginning with the 1962 Delcotronic, GM always used a transistor circuit while the points ignitions recived a passive circuit.
Is easy to convert, just depends on which tach it has. |
My memory is from one that sat in the dyno area at GMI in 1970 and looking at the pull charts.
Ken, you have some cool stuff in that garage. Be curious how that runs in the car, it should be a different animal than what's in the car now.
Ken goes WAY out his way to find all the correct hard to find little parts that bolts to the engine.Would be killer if he could find the smog setup for the engine.Tom
I'm late to the party, but WOW, that is awesome, Ken!
On the epoxy coil, there were other applications for those - I think they used them on one of the OHC-6 installations - F-body? I have no references for which part numbers though. I had a #240 red CD coil that I had planned to use on my V. Most of the magazine articles showed the epoxy coil (not all), but the '70 A-body service manual diagram shows a conventional coil with the CD amplifier, so I wasn't going to lose any sleep using it. Like has already been said, the #406 is unobtainable, and I sure couldn't have afforded it if I had found one. I am looking to use the D-R CD Ignition on my '63 Tempest build. I have a distributor, but need an amplifier and coil. If anyone has a lead, please let me know. A non-functioning box would be fine as would an Olds UHV version. I have rebuilt two of them with good results.
Hoping to finish a project while I'm still able to push the clutch in.... ![]() 1963 Tempest Convertible (Ram Air IV w/4” stroke), TKX, 9-inch w/3.70 gears and triangulated 4-link) Pictures |
Think the RAV had smog equipment but the 303 never did, was just a race engine that had too big a port to be effective. Then Titus claimed is Firebird was Canadian and the Chev 302 was leqal (wink, wink). And that was the end of the 303.
There was talk of an oval track series but don't think anything happened except a few engines went to racers. Just know there was one with FI at GMI in the early 70s. |
Factory 303s SCCA short deck engine had smog pumps when the 25 crate engines were made.Look at Kens engine and you will see the plugs in the heads where the lines were attached.DS 303 and 400 heads were not drilled and tapped for smog.i have built just about every version of the V engines from 303 short deck,303 std deck,366 NASCAR,428 and 455 3 in main along with a factory alu block.FWIW.Tom
| The Following User Says Thank You to tom s For This Useful Post: | ||
By all means, I'm not saying that your coil is wrong. Its that the delco remy transistorized / uhv ignition site only shows the 406 as the correct RAV coil. The reason I say this is because I recently aquired an NOS 406 coil, dated 9D14 in a large RAV parts trade from a well known collector.
