Old 07-16-2021, 01:00 PM
Mwieczorek Mwieczorek is offline
Originally Posted by PONTIAC LARRY View Post
Also don't forget a 3 something gear ratio needed for 4 speed since most common 66 auto cars have 2.56 (Catalina 2v) 3.08 3.23 minimum. Also I would consider a much newer 5 speed to see viability of swapping in and gain OD and maybe a deeper first gear. Aftermarket universal hyd clutch (hyd throwout bearing) set up can save you messing with unobtanium dinosaur stuff. If you find a deep gear 5 spd you may only need a 2.93 posi or something milder to get a good stop light drive away gearing in 1st.
Yeah, so now that I've done more research I'm leaning towards what you list above!
First order of business is to source a rear end with respectable gears and limited slip. I'm going to start a new thread to solicit information about suspension geometry...
Thanks!
Old 07-16-2021, 02:00 PM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Thanks!
your 66 gear interchange is between 65-70 full-size Pontiacs B body big 10 bolt cover that has a 12 bolt ring gear 8.875" 31 spline bolt in axles.
Great donor cars are Bonnevilles or Grand Prixs or Catalina 2+2 cars or any factory manual trans equipped car ... these will have a lower ratio than the average
automatic 389-2v Catalina or Star Chief.
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a
66 Star Chief Executive 59k mile 389
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2008 Saab 9-3 2.0T convertible
