Old 07-16-2021, 07:15 PM
68ragtop's Avatar
68ragtop 68ragtop is offline
A piece of masking tape rolled around the edges will be close to what you will have left once painted. Not much difference, but its worth noting. Did you fit your fenders to the bumper, gapped the hood edge & got lucky with the doors, or did you tweak the doors a bit? I started my gaps in the front and worked to the fronts of the doors. then twisted the doors to fit the quarters. backwards from how the factory did it, but it doesn't take much & every door is different I have found. My rockers also curved in slightly at the front, so I had to pull them out a fuzz. Maybe the last 5" as I recall. whenever I see cars with perfect rocker, door & fender fitment I usually wonder if they did the same thing, or they just got lucky. Never fit great from the factory, but with enough patience and willingness to modify the sheet metal here & there, they can get pretty darn close.
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
Old 07-17-2021, 07:24 AM
I will definitely be needing someone to do this for me on my 68 because I will get so frustrated and use words that aren't fit for children's ears
Old 07-17-2021, 08:13 AM
68ragtop's Avatar
I can't even begin to count the hours I have spent on fitting and modify the sheet metal for better fitment. lots of small cuts and changes you would never notice. just have to do them in the right places. I know there are some that will look at the panel fitment & say the cars should never fit that good & never did from the factory. I completely agree, But I decided 10 years ago I wanted to improve that for personal preference. just something about the reflections continuing on to the next panel & even gaps makes a big difference in the appearance. As long as you are ok with deviating from stock a bit. I have zero regrets doing that on my 68
89 Trans am GTA
The Following User Says Thank You to 68ragtop For This Useful Post:
