Roto is the only auto I know that has a flywheel instead of a flex plate.
| The Following User Says Thank You to U47 For This Useful Post: | ||
Ok then, Thank You, I’m just learning this stuff
Now I know who I can offer this to, only a Roto Hydromatic man! G |
Thanks man, attached (if I did it correctly) are photos of my trans before rebuild showing the 12 bolts, the new flex plate I found in Norwalk showing 6 bolts & 6 spaces, & the slim jim I cannot use
This picture is from a GMC Master Parts book. GMCs of that era used Pontiac V8s and continued to use the Dual-Range HydraMatic into the early 60s. Note the 30 bolt holes around the outer diameter of the flywheel and torus cover to hold the parts together.
Just to continue the discussion - or start an argument. The 1961 Hydra-matic manual shows for the Roto a flywheel and for the 315 HM BOTH a flywheel and a flex plate. Although, as pointed out, it looks like the flywheel is also the front torus cover.. And I know the caption for the Roto says 3 speed but lets not start that argument again.
