Anyone ever try to pull/stab engine with trans using a cherry picker type hoist while car is on a 4 post lift or quick jack? Thinking that setup could give needed ground clearance (maybe an additional 6-10”?) for the extreme tilt needed with trans attached. Then lift can be brought back down. The lift height of the engine hoist arm would be in question though.
1968 LeMans conv. 350 HO - 4 speed triple white (hear it idle here) https://www.youtube.com/watch?v=eVmq...ature=youtu.be 1968 LeMans conv. 350 - 4 speed Solar red/pearl |
MOST "engine hoists" sold in the last twenty years are pure trash. There were plenty of crappy ones forty years ago. Plenty of folks I talk to about engine hoists have never seen a properly-engineered engine hoist. What is SOLD as a "2-ton" hoist is really a budget-built one-ton or even 3/4 ton hoist with a too-short lifting arm because a proper lifting arm would overwhelm the crappy, undersized hydraulic ram. They can call it a two-ton hoist only because the lifting arm (boom) is so tiny. Which then means the entire hoist framework is small, thin and flimsy; but that makes 'em easier to ship from Asia. I have two engine hoists. One came from Sam's Club decades ago; the other I bought when I moved--I needed a hoist at the old house; and another at the new place. The second hoist is another of the nameless, generic junk engine hoists that will barely lift an engine; and won't lift it very high because of the short, cheap boom. If you're pulling the trans with the engine, you're gonna need to lift the thing to the moon to get the trans over the radiator. Here's what a real hoist can do: Cadillac 500, Turbo 425, suspension, steering, brakes, tires and front half of the frame from a '73 ElDorado. Consistent with safe practice, this is not anywhere near as high as it would lift, just enough to get it loaded onto the trailer. (No, the crappy hoist at the other end of the road was not used to remove this from the trailer!) |
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
The reason I did the engine and tranny together was that I had to. I did the work in my driveway and there's no way that I was going to get the transmission in from underneath after. I put the front wheels up on the drive up ramps for clearance.
