Old 09-13-2021, 04:43 PM
Scott65's Avatar
Scott65 Scott65 is offline
The recommendations so far are good if you're bolting something onto the RPM intake. Just make sure of all your long term goals. Such as, will you want mpfi (injector per cylinder, batch or sequential), will you want coil per cylinder at some point etc. I started off with the FAST ezefi which worked well. But later decided I wanted to try my hand at sequential fuel and spark. A standalone ecu allows for many options. Buy once cry once basically. FWIW
'65 Tempest 467 3650# [email protected]
The Following User Says Thank You to Scott65 For This Useful Post:
