Old 11-06-2021, 10:04 AM
markpj23 markpj23 is offline
Default Qjet Connections
I had posted this in another thread but no answers there.
I have a rebuilt Qjet ready to bolt on. It's apparently not from a Pontiac. Have a few connection ports that I'm not sure what they connect to, and I'm wondering if you guys know what the ports are for? The ones circled are the ones in question.
Can I just cap them off?
ID:	577040   Click image for larger version
Mark
Las Cruces NM
___________________________
Current Project:
'67 Catalina Convertible
400 4-spd
Old 11-06-2021, 11:37 AM
Holeshot71's Avatar
Holeshot71 Holeshot71 is offline
The big one in the front middle goes to the charcoal canister. If you don’t have one just cap It. The one to the left of that is for the choke pull off. You don’t have the pull off or the linkage that goes to the secondary air flap. You should have them both for cold start-up and to control the rate of opening for the secondary flaps. The other small one to the right is for ported vacuum to the distributor.
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55
'72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80
Old 11-06-2021, 06:56 PM
Thanks. This one has the electric choke. Do I still need the pull-off and linkage? If so could you post a picture?
Mark
Las Cruces NM
Current Project:
400 4-spd
Old 11-06-2021, 07:25 PM
Mark,
Your carb doesn't have and doesn't use a front pull-off.
The one on the rear does it all.
Clay
Old 11-07-2021, 10:51 AM
Originally Posted by "QUICK-SILVER" View Post
Mark,
Clay
Thanks - thought I was missing something...
Mark
Las Cruces NM
Current Project:
400 4-spd
Old 11-06-2021, 07:43 PM
NeighborsComplaint's Avatar
Look at the pic of the back of the carb. Choke pull-off is already connected.
Triple Black 1971 GTO
