Old 11-07-2021, 09:43 AM
Hillard's Avatar
Hillard Hillard is online now
Default 2000 Bonneville starting problems. Help
Just picked up a 2000 Bonneville. Started up just fine, shut it off, and then decided to start it up again right away and it didn't want to start. It was acting like it wanted to hit, but just wouldn't. After a few tries it finally started. General concensus was I shut if off while it was still on high idle and was just loaded up as you could smell a little fuel. Drove it home and it ran great. Stopped to get gas, no problem. Next morning it started just fine. Pulled it back to the garage to do a couple things to it. Went into town, came back, changed oil, air filter, just general maintenance stuff. Won't start. Doing the same thing. It acts like it wants to, but won't. Went to my dad's house to pick up his fuel pressure tester, came back (10 minutes) hooked up the tester, made a dumb mistake and instead of just turning the key on to read the gage, I hit the starter...and it started. Tried 3 or 4 more times periodically after that and it started every time. But I'm a little gun shy now. Any ideas??
Old 11-07-2021, 09:49 AM
salem1912 salem1912 is online now
Leave the gauge on,start it up and let it run the same as before. Shut off and see how quickly the gauge drops off and what your reading is after 1/2 hour. If it drops to 0 -10psi see how quickly it goes up to 50-55 (what ever the spec is) WITH just turning the key on. You could have either a injector leaking into the cylinders or a faulty pump check valve that's not holding the pressure forward.
'68 GTO
'69 Corvette
'75 Cadillac Coupe Deville
TOM
Old 11-07-2021, 10:04 AM
mgarblik mgarblik is offline
To take the above to the next step. If it holds pressure, the fuel system has integrity. (regulator, injectors and fuel pump are good). If the pressure drops to near zero, you have an issue. You can use shutoff valves in the feed and return lines to isolate. Shut off return valve to the tank. If pressure still drops, leaking injector, (s) . Much more common issue is failing crank sensor. They fail in an intermittent mode all the time. Do a quick check for ignition, next time it won't start. Also, next time it won't start, hold the pedal WOT and see if it starts. That would indicate a leaking injector as well. 3800's are pretty easy to deal with for the most part. Take care.
Old 11-07-2021, 10:16 AM
Bob Dillon's Avatar
Bob Dillon Bob Dillon is offline
Location: Gilroy, California, USA-Garlic Capital of the world!
Thumbs up
Go over to Pontiacbonneville.com, join, and describe your problem. There's a million buys there who can help.
I would also suspect the security system. An easy fix, but annoying,
"Democracy is a beautiful thing, except for that part about letting just any old yokel vote."
~Jack Handey, Deep Thoughts
Old 11-07-2021, 11:20 AM
"Much more common issue is failing crank sensor."
Quick check on a crank sensor would be if car has a tach see if the needle is moving while cranking or scan tool show any rpm while cranking.
'68 GTO
'69 Corvette
TOM
Old 11-07-2021, 11:38 AM
LPete LPete is offline
It’d be interesting when it doesn’t start to hold the throttle wide open and see if it starts (treating it like it’s flooded). Some models seem to flood when started cold a couple times and not run for a bit.
The other suggestions are great.
Lee Peterson
"I didn't expect a kind of Spanish Inquisition...!"
'69 Cameo White RA III Judge, 4 speed, owned since 1977 -- my first car.
Old 11-07-2021, 12:05 PM
Hillard's Avatar
I've had one before with a bad crank sensor. This one acts a little differently than my other one did. My other would just act like the ignition is turned off when cranking. This one acts like it's trying to fire but won't.
The fuel pressure with it running was at 45 psi. I think they are supposed to be 45-50??
Old 11-07-2021, 01:10 PM
That is a great "quick and dirty check". No tach wiggle or 75-150 RPM on the scan tool, you have your answer.
Old 11-07-2021, 01:13 PM
See what the pressure does when you key off? If you determine the injectors are a problem, pull them out and get them to me. I can ultra-sonic clean them and flow test them. I would need them for a week if you can be without.
Old 11-07-2021, 04:56 PM
Hillard's Avatar
Started the car several times today. No problem. Put the fuel pressure gauge on it and it was between 45 -50. Left it on for 45 minutes and it was at 32. Is that an issue?
Old 11-07-2021, 07:23 PM
I would say that test is slightly inconclusive. Probably not an issue. I would move in the direction of verifying the ignition is functioning when it won't start. Is there a chance this model has the trouble prone Motorola ignition? Or is it the Delco system with the 3 separate coils?
Old 11-07-2021, 08:56 PM
Hillard's Avatar
I don't know. I didn't pay any attention to that Mike. I'll look tomorrow and get back to you.
I've driven it to a few diferent places today, started it about 8 or 9 times and haven't had any issues.
Thanks.
Old 11-07-2021, 10:00 PM
32 is low, I don't work on many GM but does the car have a vacuum operated fuel pressure regulator up on the rail? If so unplug while running and see if that 32psi goes up. Also see if fuel is coming out that nipple,had one that was leaking though the diaphragm causing rich mixture screwing up the o2 sensor.
'68 GTO
'69 Corvette
TOM
Old 11-07-2021, 11:45 PM
Hillard's Avatar
To be clear, the 32 was after I shut the car off. Was watching it to see if it leaked down fast or what would happen. After 10 minutes it was still close to 45. Then I got sidetracked doing other things and came back to it at 45 minutes. For all I know that leakage could have been in the gauge. With the key on it's always been at 45 to 50. And yes, it does have a vacuum operated regulator.
Old 11-08-2021, 10:22 AM
Bob Dillon's Avatar
Arrow
My '99 Bonneville had the Delco coils.
I gave the wrong address for the club. Here it is. http://www.pontiacbonnevilleclub.com/. Lots of good info here.
45-50 pounds while running is perfect.
Old 11-08-2021, 01:07 PM
Hillard's Avatar
So I drove it to work today and just went to lunch. On my way to town the "Service Security System" alarm came on. I've made 2 stops since then and it has restarted every time without hesitation, but the alarm makes me wonder if that isn't the issue. I knew of an Oldsmobile that had starting issues and it was found that there were some corroded or broken wires going to the anti-theft system causing the problem.
Old 11-08-2021, 01:35 PM
Bob Dillon's Avatar
Thumbs up
Yeah. The wires are tiny and frequently break.
What you need to do is use an ohm meter to "read" the key to see what the reading is. Next, your order the resistor (I got mine at Radio Shack, RIP) and they were 5 for a dollar. I'm sure amazon has them.
You just wire the resistor into the circuit before the key and that solves the problem. I've had 2 Bonnies, a '99 and '97, and they both eventually failed and required this fix.
If you got over to pontiacbonnevilleclub.com and search the archives, this fix will pop up, and it's an easy fix.
Old 11-08-2021, 02:54 PM
Hillard's Avatar
Thank you.
Old 11-09-2021, 09:59 AM
To add to the security system issues. It is very possible that is causing your problems. The tiny wires are under the steering column. Green, yellow, white, I think. They are like 24 gauge, very small. You can bypass the system by supplying the correct resistance to the module and bypassing the key chip as mentioned above. Pretty easy. There are several Youtube videos showing how to do it. I have done half a dozen over the years.
Old 06-14-2022, 10:28 PM
Hillard's Avatar
Old thread, new problem. Car was running rough and even died a few times. Put a scanner on it and it said Mass Air Flow Sensor. So I replaced it. Now it runs down the road ok, but idles rough. Doesn't die but will act like it's going to and the idle will fluctuate from 600 to 1100. Scanner just says idle rpm unusually high detected. But doesn't say why. Any ideas?
