Old 11-08-2021, 01:07 PM
Hillard's Avatar
Hillard Hillard is offline
Originally Posted by Bob Dillon View Post
Go over to Pontiacbonneville.com, join, and describe your problem. There's a million buys there who can help.
I would also suspect the security system. An easy fix, but annoying,
So I drove it to work today and just went to lunch. On my way to town the "Service Security System" alarm came on. I've made 2 stops since then and it has restarted every time without hesitation, but the alarm makes me wonder if that isn't the issue. I knew of an Oldsmobile that had starting issues and it was found that there were some corroded or broken wires going to the anti-theft system causing the problem.
Old 11-08-2021, 01:35 PM
Bob Dillon's Avatar
Bob Dillon Bob Dillon is offline
Location: Gilroy, California, USA-Garlic Capital of the world!
Thumbs up
Yeah. The wires are tiny and frequently break.
What you need to do is use an ohm meter to "read" the key to see what the reading is. Next, your order the resistor (I got mine at Radio Shack, RIP) and they were 5 for a dollar. I'm sure amazon has them.
You just wire the resistor into the circuit before the key and that solves the problem. I've had 2 Bonnies, a '99 and '97, and they both eventually failed and required this fix.
If you got over to pontiacbonnevilleclub.com and search the archives, this fix will pop up, and it's an easy fix.
"Democracy is a beautiful thing, except for that part about letting just any old yokel vote."
~Jack Handey, Deep Thoughts
Old 11-08-2021, 02:54 PM
Hillard's Avatar
Thank you.
Old 11-09-2021, 09:59 AM
mgarblik mgarblik is offline
To add to the security system issues. It is very possible that is causing your problems. The tiny wires are under the steering column. Green, yellow, white, I think. They are like 24 gauge, very small. You can bypass the system by supplying the correct resistance to the module and bypassing the key chip as mentioned above. Pretty easy. There are several Youtube videos showing how to do it. I have done half a dozen over the years.
