Old 11-12-2021, 11:40 AM
Bill Hanlon's Avatar
Default '55 only hydraulic lifters
Not mine
https://www.ebay.com/itm/15469233486...AAAOSwtDVhipTF
Old 11-14-2021, 09:52 AM
buds56's Avatar
buds56 buds56 is offline
What is the difference in the 55 lifter from the 56 &newer?
I see they are different part numbers,
I thought the only valvetrain differences was 55 had adjustable rockers, Different rockers, studs, nuts.
Just curious
Old 11-14-2021, 12:56 PM
I think (but have NO first hand knowledge) that the oil supply was at a different height in the lifter bore, therefore the oil supply grooves in the lifter is inn a different position.
Old 11-14-2021, 02:52 PM
tom s tom s is offline
I think those are called "lowball" lifters.If you have a later lifter check the diff of the seat.I think after talking to Nunzi years ago I used a set with longer pushrods.Tom
Old 11-14-2021, 04:43 PM
If the oil band is low, wouldn't SBC lifters work?
Old 11-14-2021, 06:48 PM
951 and one of my 5230620 lifters
ID:	577872   Click image for larger version
ID:	577873   Click image for larger version
ID:	577874   Click image for larger version
Old 11-14-2021, 06:51 PM
oil hole in same place,push rod cup is lower.I can measure how much if interested.Tom
Old 11-16-2021, 08:10 AM
Safari Larry's Avatar
Safari Larry Safari Larry is offline
See http://www.pontiacsafari.com/Service...09-October.pdf, page 102.
Name:	55-56 lifters.jpg
Larry Gorden
POCI 1956 Tech Adviser
www.PontiacSafari.com
The Following User Says Thank You to Safari Larry For This Useful Post:
Old 11-16-2021, 11:09 AM
Interesting the lifters I have on hand the oil hole looks in the same location although larger?The 56 looks higher than the 951s also?Tom
Old 11-16-2021, 11:47 PM
text from Larry's post above: "A new valve train is used and requires no adjustment (Fig. 10). This was accomplisheo by moving the valve lifter oil supply hole upward to insure ample oil reserve (Fig. 11)"
