Old 11-15-2021, 08:51 PM
Doubt they ordered a column shifter.
If they did not order the console the shifter would be on the column.
Old 11-15-2021, 09:14 PM
Sirrotica's Avatar
One question John, if you order power windows, don't you need a console to mount the switch in? I've never seen an early 70s second gen with power window switch anywhere but in the console, but I don't claim to know all the intricacies of second gens. It just occurred to me that there would be no place to mount the power window switch......
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 11-15-2021, 09:36 PM
Elarson's Avatar
Elarson Elarson is offline
The original owner ordered it without console.
Eric
Old 11-15-2021, 10:18 PM
Thanks, Eric.
I'd have to look it up, but the power windows would probably require a console?
Old 11-15-2021, 10:23 PM
Had to look it up.
551 Power Windows $78.00 - Requires Console (431)
The Following 2 Users Say Thank You to johnta1 For This Useful Post:
Old 11-18-2021, 08:34 PM
mgarblik mgarblik is offline
Owner and I worked on the fuel tank this week. As I mentioned earlier, he opted for a Spectra Premium replacement tank without filler neck as the correct neck is not available for a 74 car. The OE tank was a real mess with 40 years of evaporated fuel in it and numerous holes and so forth. The Spectra tank is Canadian made and pretty nice. It has nice sharp feature lines in the stampings and nice finish. The only item we weren't crazy about was the copper tube they used for the vapor return line. But it was already soldered in place and there wasn't a compelling reason to remove it. We decided to double flare it and use a flare union, then marry it to the original vapor line which was still in good condition. We also silver soldered in the old neck into the new tank after thorough cleaning of the neck. 8% silver solder is a little tricky to use but it came out nice and is leak free, verified by a smoke test with my evap. tester. Also, he stripped the paint off the OE cap to reveal a factory epoxy primer of some sort of rust resistant primer. Ready to install in the next few days.
ID:	578065   Click image for larger version
ID:	578066   Click image for larger version
ID:	578067   Click image for larger version
ID:	578068   Click image for larger version
Old 11-19-2021, 06:46 PM
3tas4me's Avatar
3tas4me 3tas4me is offline
Looks great!
On my '74, the original fuel cap seemed to be plated with yellow zinc. I had it plated again the same way.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1996 Trans Am WS6
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
The Following User Says Thank You to 3tas4me For This Useful Post:
