The original owner ordered it without console.
Eric
"Everybody has a plan until they get punched in the mouth" noted philosopher Mike Tyson Life begins at the end of your comfort zone. The mind, once stretched by a new idea, never returns to its original dimensions. |
Thanks, Eric.
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! W.E.C moment "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." Socrates |
Had to look it up.
![]() 551 Power Windows $78.00 - Requires Console (431)
| The Following 2 Users Say Thank You to johnta1 For This Useful Post: | ||
Owner and I worked on the fuel tank this week. As I mentioned earlier, he opted for a Spectra Premium replacement tank without filler neck as the correct neck is not available for a 74 car. The OE tank was a real mess with 40 years of evaporated fuel in it and numerous holes and so forth. The Spectra tank is Canadian made and pretty nice. It has nice sharp feature lines in the stampings and nice finish. The only item we weren't crazy about was the copper tube they used for the vapor return line. But it was already soldered in place and there wasn't a compelling reason to remove it. We decided to double flare it and use a flare union, then marry it to the original vapor line which was still in good condition. We also silver soldered in the old neck into the new tank after thorough cleaning of the neck. 8% silver solder is a little tricky to use but it came out nice and is leak free, verified by a smoke test with my evap. tester. Also, he stripped the paint off the OE cap to reveal a factory epoxy primer of some sort of rust resistant primer. Ready to install in the next few days.
Looks great! On my '74, the original fuel cap seemed to be plated with yellow zinc. I had it plated again the same way.
1970 Trans Am 1971 Trans Am 1974 Trans Am 1978 Y88 Trans Am W72/auto 1979 10th Anniversary Trans Am 1984 Trans Am 1996 Trans Am WS6 1999 30th Anniversary Trans Am 2001 10th anniversary Firehawk #104 |
| The Following User Says Thank You to 3tas4me For This Useful Post: | ||
