What is the difference in the 55 lifter from the 56 &newer?
I see they are different part numbers, I thought the only valvetrain differences was 55 had adjustable rockers, Different rockers, studs, nuts. Just curious |
I think (but have NO first hand knowledge) that the oil supply was at a different height in the lifter bore, therefore the oil supply grooves in the lifter is inn a different position.
I think those are called "lowball" lifters.If you have a later lifter check the diff of the seat.I think after talking to Nunzi years ago I used a set with longer pushrods.Tom
If the oil band is low, wouldn't SBC lifters work?
951 and one of my 5230620 lifters
oil hole in same place,push rod cup is lower.I can measure how much if interested.Tom
See http://www.pontiacsafari.com/Service...09-October.pdf, page 102.
| The Following User Says Thank You to Safari Larry For This Useful Post: | ||
Interesting the lifters I have on hand the oil hole looks in the same location although larger?The 56 looks higher than the 951s also?Tom
text from Larry's post above: "A new valve train is used and requires no adjustment (Fig. 10). This was accomplisheo by moving the valve lifter oil supply hole upward to insure ample oil reserve (Fig. 11)"
