https://transmissioncenter.net/shop/...-measurements/ 4L80E 2 WD standard length 32 11/16" Short tail T 400 28 3/8" By my math, 4 5/16" longer. It has been mentioned that the earlier cores have more less clearance problems with cooling line, tunnel clearance than the later ones. There is a kit to use with the later transmissions to help with the clearance problem. Banjo fittings to go to 6AN hoses on late 4L80E: https://www.ebay.com/itm/16435874270...RoCHyUQAvD_BwE
Brad Yost 1973 T/A (SOLD) 2005 GTO 1984 Grand Prix 100% Pontiacs in my driveway!!! What's in your driveway? If you don't take some of the RACETRACK home with you, Ya got cheated ![]() ![]() ![]()
| The Following User Says Thank You to Sirrotica For This Useful Post: | ||
Also, I read in another thread one has to clearance the trans tunnel a bit to clear trans lines. Do the 90 degree fittings provide the adequate clearance without banging on the tunnel?
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb Last edited by grivera; 12-10-2021 at 09:45 AM. |
The HD originally has the parking brake on the rear of the transmission because the HD trucks have 4 wheel disc brakes. I actually own one of these trucks, but have never taken all the parking brake parts off to see what's under it. I'm still moving stuff from my old house to the new one and using this truck with electric gate, and box body to move, so I can't answer that question.
I've never seen anything in print that you can't use the HD transmission, maybe a call/E mail to Jake's would give you the answer about what parts are different , if any on the HD transmissions. I did a quick search and found this about output shafts: https://ls1tech.com/forums/automatic...-variants.html I also found this, and it says that the HD version is actually a beter candidate because some of the better parts in the transmissions: https://ls1tech.com/forums/automatic...-4x4-swap.html I guess I'll be looking for the HD/motorhome versions from here on out....
