Old 12-19-2021, 04:48 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Really impressive numbers for that small cam and low compression
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
Old 12-19-2021, 04:57 PM
ta man ta man is offline
I think the test DA was really good as well...I'd like to know more details on the cam install??
Old 12-19-2021, 05:49 PM
SD455DJ SD455DJ is offline
The cam was degreed to verify specs and installed "dot to dot" (straight up) and that put it a 108 degrees, or 4 degrees advanced.
Dennis
Old 12-19-2021, 06:12 PM
Thanks OCMDGTO! This W72 is a good and careful rebuild (not blueprinted like an NHRA stock class racer) with good quality forged pistons and rods, careful finish hone on the cylinders for moly rings. There is no head or manifold porting, let alone any port matching, smoothing, casting flash removal at all. It's a low compression pure stock type build with the benefit of factory RA exhaust manifolds and Pypes 2.5" mandrel headpipes. The exhaust system is a distinct improvement over stock by 10 hp/lbft. If the engine was built with the max allowed compression (8.1 + 1.5 = ) of 9.6 to 1, it would make in the 380 hp/470 lbft range, the cam being the limiting factor.
Dennis
The Following 2 Users Say Thank You to SD455DJ For This Useful Post:
Old 12-19-2021, 06:15 PM
Thanks Steve25, PAUL K, Skip Fix, and dragracerx2813 for the compliments!
Dennis
