So recap -
* 700HP limit is NOT an accurate statement... (I always believed it had more to do with rotational weight and mean piston speed ratios)
* Short Stroke + Boost + Proper tune = Well over 700HP capability
* Charlie with his 206 cid 4 cylinder Turbo engine making 800 HP has in fact been on a DYNO.
Its a shame the P350 has been shunned to the point it is considered better used as boat anchor than a high performance engine. It would be awesome to see someone build one to handle 25+lbs of boost.... Wallace racing calculator suggest that if you build a P350 that makes 350HP and add 25lbs of boost... you would be making 945HP... 30lbs boost raises it over 1,068HP... Sounds like a fun project to me...
SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t"
