I need some help with the p/w wiring. putting my 70 back together I cant find the power wire. (red)? . or where it plugs or gets power from
I cant find a wiring diagram for the harness |
Orange / black. believe, and plugs into fuse box in the middle in "Ign" here is your diagram for 70 and 71
" Long may we DRIVE !" Last edited by Formulabruce; 01-13-2022 at 04:09 PM. |
Thank you much!
my 65 has a relay on engine side of firewall . I knew there wasn't a fuse but couldn't find any lose plugs . or a relay
I will check under dash for something unplugged. now I have a idea what to look for |
This page has some pictures and info that might be useful to you.
http://www.firebirdtransamparts.com/...dows/power.htm |
Yes ,
The pics really help. So the wire that plugs to the fuse panel powers the relay . Thanks for that This car has power locks also . so far they only unlock . I don't have seats in yet . So I'm thinking the seats work with locks . may need to install seats to search issue that out |
The seats on some later models had a switch for the seat belt light, but nothing else.
If your locks only work one way then most likely it's either the contacts on the switch, or the solenoid itself is worn out. I have a pair of solenoids and they work on the bench, but they aren't strong enough to lock the doors. |
Locks are independent of seats. The PDL actuator is a 2 way Solenoid so reversing the Hot is what unlocks or locks the door.
Only one direction usually means a switch issue if its both doing same thing. Newer cars use a stepper motor and a worm gear thats much lighter, more reliable and uses way less current. Easy to upgrade and not seen.
" Long may we DRIVE !" Last edited by Formulabruce; 01-15-2022 at 08:18 PM. |
my seats lock and un lock with a door jam contact . like the dome light does.
Formulabruce , i looked at the ones from Ames . If i don't get these to operate correctly . I will go in that direction .Do you have experience with there's. the locks worked on the bench . But don't even make a noise in the car . I will switch the wires to see if its the switch . Are those switches available ? thanks Don |
I run a MES system and use a remote to keep keys off the car.( door locks) This can be wired with the dash switch, or without.
" Long may we DRIVE !" |
Here's some pics from the 70 Firebird Supplement:
![]() ![]() ![]() and the wire color code: ![]()
Seat Back Diagram:
| The Following User Says Thank You to johnta1 For This Useful Post: | ||
The seat back locks are included in the P/L option . so says the car shipping record . see pic
I do know this, the newer motor/worm gear door lock units work much better and use less power and weigh much less than the heavy Solenoids. Yours seats have the solenoids in them still?
yes and work!. actually everything worked. the locks were interment , like the switch was bad . car wasn't hateful when I got it from guy in Michigan. 20 hour ride straight up and back to Maryland
note the relay on floor for seat backs |
