| Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
Looking for a pair of ‘71 HO heads. Ported heads considered. What is out there?
Intake manifold and crossover (originals) preferred. May consider a reproduction intake with correct casting numbers. Thanks, Jim
Jim www.raceV8s.com 1972 Trans Am drag car, 3300lbs, 468 ci, Iron D ports, 428 block, 9799103 crank, 9.48 @ 143mph, 6.0 @ 114mph in the 1/8th. |
Jim I’ll take a look and see what I have available. I have plenty of original 1971 HO parts. You don’t want a reproduction intake either. The fit/quality is extremely poor. Do you need these parts for a restoration? Feel free to email me directly. Thanks, Jeff Sent from my iPhone using Tapatalk |
Hi Jim: I have set here if your interested. Shipping cost would be probably high. Would have to go truck freight. https://forums.maxperformanceinc.com...11#post5978911
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick. Best so far 9.95@135 mph. 1.39 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exhaust 950 Quickfuel. |
A set on Ebay.. https://www.ebay.com/itm/28454111993...wAAOSwBnxhnb5x
Jim I will second on repops being way off but nothing some TIG weld and remilling usually can't fix. But they do not look perfect in the casting number area, so if going for a numbers matching I'd hunt up a factory intake.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
I have a complete running 455 std bore with 197 heads. Block is not correct date. Heads and intake are correct. I have it for sale. Price is 6500 firm. Thanks.
