ive always heard that you dont want to grease roller bearings like these or modern pulley bearings in serpentine systems, the thin clear grease they come with is what they are designed for & all thats needed. been told that adding the wrong thick grease like chassis or wheel bearing grease causes the balls to not roll right & can or will make them slide on the race & not roll.
not sure if thats 100% true but ive been told that by reputable long time mechanics as well as bearing manufacturers when i asked about greasing them. yes the factory installed grease can dry up but usually not until the end of its service life, maybe adding some grease at that point can extend the life a bit but ive always trusted the dont add grease thing & left them alone with what they come with. just mentioning what ive heard a lot more than one time on greasing roller bearings. for removing a pilot bearing thats a bugger to get out i did use the trick of packing the crank bore with grease & using a rod just a tad smaller than the bearing opening to pound it in & have the grease force the bearing out. |
You stick to your theory, and I'll continue doing it the way I've done it for 50 years........... ![]() Hopefully you don't replace tapered wheel bearings using the same theory. I'm wondering why someone would stake the bearing, when it can't move unless the transmission is removed?......... It's pretty much captive as soon as the input shaft is installed.If someone was worried that it didn't fit tightly, a couple hits with a prick punch on the interior of the crank bore can tighten it in the bore. Most times I install the bearing, grease it as outlined, and finish the job. |
The only reason I mentioned to stake the bearing as I've had them a bit too loose and staking helps to keep the outer race from rotating. If the bearing installs nice and tight Probably doesn't need to be staked. I assumed if your installing a bearing you know the procedure. That's all. like your little Emoji..
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick. Best so far 9.95@135 mph. 1.39 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exhaust 950 Quickfuel. |
I guess two ways to arrive at the same end. That bit of advice he gave me has been invaluable many times over the years. They hadn't invented Loctite bearing mount yet....
| The Following User Says Thank You to Sirrotica For This Useful Post: | ||
not much dirt is able to get into the area of a pilot bearing, when i removed mine at ~50k miles & 40+ years old the inside of the crank bore was basically spotless & the bearing itself was very clean looking. these pilot bearings arent designed or needed to be sealed... & a tapered wheel bearing is completely different than a roller bearing... they are designed for thick wheel bearing grease & operate a little different than a ball bearing, the comment about "hope you dont replace tapered bearings using the same theory" makes no sense since they are not the same type of bearing & obviously dont come pre lubed with a specific grease & require packing with wheel bearing grease. lots of people do things different than what the manufacturer or repair manual says to do, i do it too sometimes & it usually "works" ok, but that doesnt mean its what the engineers & manufacturers of the part recommend to do. EDIT: i just called timken to confirm what they suggest for this, spoke to the auto tech dept & asked about greasing a pilot bearing for a 1978 firebird & he looked up the part #. he said they specifically do not recommend adding any grease to these, they are supplied with a special synthetic grease that lasts the life of the bearing. i asked if it would be ok to put some other grease like chassis or wheel bearing grease & he said its not recommended & then repeated what ive heard & mentioned above, it will or can cause the ball bearing to not roll & rotate right & cause heat & premature wear. straight from the horses mouth. do what you want but i will leave my pilot bearing as designed & if/when it fails or the grease dries up i will buy another one for a few bucks. Last edited by 78w72; 01-27-2022 at 05:34 PM. |
| The Following User Says Thank You to 78w72 For This Useful Post: | ||
Jeff |
| The Following User Says Thank You to geeteeohguy For This Useful Post: | ||
i said that using wheel bearing or chassis grease in a pilot bearing wont cause it to self destruct, just stating they are not designed to use it for the reason timken & many others say. they come pre lubed with the correct type of grease, add whatever type & amount you want, but doubting what the engineers that design them say to use doesnt really make much sense IMO. Last edited by 78w72; 02-01-2022 at 05:09 PM. |
just put a dab of grease(hi-temp)in the cranks recess and around the bearing and install.Done!! You do not want excess lube to be thrown on to the clutch.
I've worked in maintenance shop, we had many pieces of equipment that had ball bearings in it, guess what we used to lube it, wheel bearing grease. The points you make have little merit, so I'm not going to argue back and forth about grease, to dignify your remarks. I know what works, I don't need your blessings, or the guy that answers the phone on the tech line at Timken. Not everyone uses Timken bearings. I've taken other brands of pilot bearings out of the wrappers that were dry. So in that case, would you install them dry? I know that what I've been doing for 50 + years are good practices, I know that wheel bearing grease works fine for pilot bearings in a Pontiac. Jeff told you the exact same thing that I did. He and I have close to 100 years spinning wrenches in the automotive field. Maybe you can BS a newbie about your claims, but we're far from newbies. This isn't the first time you've tried to contradict advice I've given on this forum. Who goes to the trouble to call Timken, to deliver second hand information just to be contrary to a post I made? If you disagree with my advice, just block me so you don't have to see it. I try to be helpful to people on this board by posting tips and things that make working on these cars easier, gained from my father that worked at a Pontiac dealer in the 30s, until he retired in the late 70s. Plus my own experience that I've gained since I graduated from high school/trade school in 1970. I don't give out bad advice to members, and I made a living doing it for 50 years, plus built, and drove my own race cars as my hobby. I have a understanding of what works, and what doesn't. FWIW, I've seen engineers make mistakes too, they're only human. I wouldn't put all my trust in choice of grease, just because someone has a piece of sheepskin on their wall. Common sense doesn't come with a degree.
Brad Yost 1973 T/A (SOLD) 2005 GTO 1984 Grand Prix 100% Pontiacs in my driveway!!! What's in your driveway? If you don't take some of the RACETRACK home with you, Ya got cheated ![]() ![]() ![]()
