If that is a Butler cam he typically uses Comp Xtreme Energy lobes. If they are lobes 3317 & 3318 then your valve lift with a 1.65 ratio would be .594" / .618".
You might consider Comp QXI lobes listed on page 24 here: https://www.compcams.com/lobe-catalog They would raise your valve lift to 0.658" which would better take advantage of your cylinders heads. If these are Butler heads I suspect that 340 cfm number is at 0.700" lift.
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
