#101
GTO George |
#102
Picture of the ARP2000 head stud
GTO George |
#103
George, are these the fasteners that can be affected from the oils on your hands? Some ARP fasteners you need to wear gloves when handling them.
#104
But the 700$ rod bolts for Crower billet rods require gloves. Not sure what the name/number those 700$ bolts are. |
#105
The L-19 bolts are the ones your supposed to use gloves with. Some builders brush ARP lube on their fingers instead.
| The Following User Says Thank You to PAUL K For This Useful Post: | ||
#106
Just curious George why don't you use the high quality studs your pals at KRE sell? |
#107
Let me tell ya this ARP2000 from outfront mototsports are way better then ARP8740 studs! GTO George |
#108
Why doesn't KRE offer them as an upgrade option?
#109
http://www.bhjproducts.com/bhj_conte...ooling/org.php |
#110
I'm thinking the same thing for Butler...It seems like they would be a great upgrade option.
#111
I am also wondering why they dont put any sort of receiver groove in the head...Tom V explained the basics of the rings, and how they work, but it just seems like they'd be even better with a few thou receiver groove. |
#112
I have one of those on my turbo setup IA2. The ring will cut its own groove to the head. Thats how it seals the bore. So when you remove the heads, u need to get it milled .005 to make it flat again.
#113
So yours is dry decked too? How much boost have you made?
#114
Dry deck and reverse cool. I only had it to 15 psi on the dyno.
#115
How did you do the reverse cool?
#116
I got a billet timing cover that I bought from a PY member and used a SBC nascar water pump and reverse cooled it. Not sure if it was actually better but I did it anyways.
#117
Just a note.When you eliminate the head gasket thickness you have to make an adjustment in the piston to head clearance.
Checkered Flag Machine & Ceralli Competition Engines Racing engines and induction development http://www.checkeredflagmachine.net/ |
#118
Really? Wouldn't there be a number of combustion chamber shapes in which that could not work? In my ignorance, I assumed that a matching groove was cut in the head.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926}
#120
Marty's ring, will cut into the head on its own. That is how it seals as the rings are not flat on one side. It is raised on the outer wall of the rings and that is responsible for sealing.
