Old 02-28-2022, 07:38 PM
TxSportCoupe's Avatar
TxSportCoupe TxSportCoupe is offline
Performer for the street. Has better bottom end torque than RPM. Less weight and better heat dissipation than Iron. Holley Street HP 750 on a 1” phenolic wood spacer. No choke. Mechanical secondary. You’ll have to feather the throttle to keep it alive for the first 20 seconds. Guarantee you’ll be in the zone on air fuel mixture out of the box and it will be snappy and not run out of fuel on the back end of a hard run. New polished aluminum body helps keep fuel from flashing over and vapor locking. Looks and runs fantastic. Best all around combo I’ve come up with in 40 years.
Old 02-28-2022, 09:53 PM
1bad65's Avatar
1bad65 1bad65 is offline
Appreciate the feedback. I'm probably going to use what I have (Performer & 650DP) and see how it goes.
The Following User Says Thank You to 1bad65 For This Useful Post:
Old 03-01-2022, 11:54 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Sounds like a plan.
