I know you can’t on the Warrior,fix is sell it and get a Bathtub while they will be available.Shameless plug again.Tom
The T-II will make the most power on your build, requires at least a 1" spacer and 850cfm carb. -My 455 is making somewhere around 5590575 HP with just a angled 3/8 spacer to get the Shaker level!
I'd kind of keep the 2x4 setup myself too! I would think there would be a progressive linkage that would work. Back when I had sideways Holleys on my 409 all 8 bbls opened at the same time-but then gas was 0.30/gal
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
37 Pontiac Sedan 455 700r4 94 Firehawk Supercharged 5.7 LT1 6spd. 71 GTO base 400 A/T 97 F250 7.3 turbo diesel |
Hey Scott, does the dual TBI set up require a progressive linkage to be used?
No. You don't need it, it wouldn't have any benefit. My experience is with the FAST system. It ties them together 1 to 1 so that it only needs one tps.
'65 Tempest 467 3650# [email protected] |
Yea the tiny plenum connecting the two on a Warrior/Nash(I have one also) might not flow enough or have bad distribution issues. I always though using an Edelbrock upper plenum from a SBC/BBC intake might work better.
One day-a throw down spare motor to test my Warrior/Nash, M/T and that Bathtub when Tom gets them done on the dyno!
