Old 03-02-2022, 11:27 AM
mgarblik mgarblik is offline
There are better alternatives out there in the 455 world. I recently bought 2 early 70's 455's for $500.00 for the pair. They are still out there. Both standard bore. 2 bolt main. To properly install and surface 8 sleeves, then torque plate hone the block, you are looking at close to $2200.00 around here. That aftermarket block starts looking pretty darn good at that point. When your done, you still have a lower grade iron block with a compromised deck. Unless a numbers matching trailer queen, I would start fresh with a better block. JMO. On the flip side, I had a customer with an early street hemi in a numbers matching factory lightweight Plymouth. We welded up 6-8 external cracks in the block, put 8 sleeves in it, welded a repair in the block to hold 2 center caps and band aided it back together per the owner's request. He had well over 5K in the block repairs. It survived the dyno. No idea how it did after that. No warranty of any kind on repairs like this .
Old 03-02-2022, 11:31 AM
PAUL K's Avatar
PAUL K PAUL K is offline
And saving the numbers matching engine increased the value of the car considerably more that the cost of repairing the block.
Good job Mike!
Go fast, see Elvis!
Old 03-02-2022, 07:59 PM
Good job Mike!
Noooo way I can take credit for all that Mopar work. We farmed out the welding to a shop with that makes commercial stainless steel products. Steve, the welder is just the best. Than Blaine at my school, is the Rottler boring mill expert. He bored it for sleeves. I installed the sleeves, decked it and honed it. It takes a full crew to fix a mess like that. I have to say, it came out better than expected.
The Following 3 Users Say Thank You to mgarblik For This Useful Post:
Old 03-02-2022, 01:08 PM
I definitely don’t want to spring for 8 sleeves, I don’t plan on pushing this engine hard. Solid point about the comparative cost of the aftermarket block.
Wow. Lotta work, but it makes sense for such a rare engine/car combo.
The Following User Says Thank You to Joe-Touring For This Useful Post:
