Old 03-02-2022, 08:18 PM
455dan's Avatar
455dan 455dan is offline
Originally Posted by Joe-Touring View Post
1971 YC, believe the casting # is: 485428
Indeed, I was really hoping to be able to get a 455 back on the road. Seems like there aren’t many around up here in the PNW.
Not sure of what part of PNW but here is a Spokane ad for some blocks
from ad ( All are standard bore, buildable cores to my knowledge)
has a 428 no main caps, and others including a 455 for $700
couple decent year 400's - 68 WT and YS for what seems pretty reasonable
https://spokane.craigslist.org/pts/d...435800786.html
1984 RX7 Jim Hand style 455 /200 4R Project car
67 White/Gold GTO 4 speed sold, 1968 GTO 4 speed sold, 1969 GTO auto sold, 68 Firebird 400 4 speed (455) sold, 65 GTO Night Watch Blue 4 speed sold, 64 GTO Nocturne Blue 4 speed sold, 71 GTO Gold auto sold. 1975 Formula 400 auto sold.
Hopefully to be restored, H-"O" Racing 73 Trans Am SD 4 speed,
Sons 70 Formula 400 auto, and wife's 1974 AMX 360 auto, 1975 Jeep Honcho 4x4, 1965 Buick Special post
Old 03-02-2022, 09:04 PM
RAIV55 RAIV55 is offline
Looking at the test sheet it appears cylinders 1,5 &7 are thin on the major thrust. I would be inclined to find another block rather than doing the work to this one.
Probably wouldn't trust the guy who sonic tested it with a Pontiac, he missed on the cylinder numbering...rookie mistake...
Monty Frerichs
B&M Machine
Box Elder SD
The Following 2 Users Say Thank You to RAIV55 For This Useful Post:
Old 03-03-2022, 04:14 PM
What is the consensus for minimums on thrust and non thrust surfaces? The machinist recommended 0.150” on the thrusts, and 0.100” everywhere else.
I noticed that, I am slightly apprehensive about the shop. The owner/main machinist was not the guy doing the sonic check or the sleeve removal.
Old 03-03-2022, 04:39 PM
Gach's Avatar
Gach Gach is offline
Let me add this. X-ray vision? All an ultrasonic inspection will do is confirm there is enough material in the primary thrust face to machine out. Blocks corrode internally; they also suffer from coolant erosion and cavitation. I know of two ‘ blocks that had primary thrust face cylinder walls that were less than .090 thick. The MINIMUM primary thrust face cylinder wall SHOULD be .150-.180. Align honing simply insures that the main saddle alignment is correct. It’s a simple process that removes a modicum of material from the main caps and the main saddle. At most, .003 005out of the caps and .001-.003 out of the main saddle. Iron DOES distort over forty years of heating and cooling cycles. Have them check the cam bore alignment as well.
I’m sure you’ve already made a decision, but the above just something to think about.
The Following User Says Thank You to Gach For This Useful Post:
Old 03-03-2022, 05:02 PM
Gach's Avatar
I would definitely also have the main saddles checked it would be a nightmare to sleeve or what ever way you decided to go, only to find out later, you ended up with main bearing issues same on cam bore.
This was a few years ago, a friend went .030, just a street car. Although he did have it magged, but never Sonic tested. Finally just to see what it would do he line up, with a Chevelle on the street. Second race white smoke coming from passenger side. First thought head gasket. After we pulled it down found nice big long crack.
I personally after checking to blocks found third one to be good. Of cruse my plain was racing.
Old 03-03-2022, 08:51 PM
The rule of thumb I was taught was .135 MINIMUM on the primary thrust wall and .100-.110 MINIMUM on the other walls. This assumes you are using the engine for street use ONLY, are utilizing the lightest piston/pin/ rod combination you can afford and are keeping the RPMs down. The lighter the reciprocal mass the less stress on the cylinder walls.
Dr. Thomas Sowell
The Following 2 Users Say Thank You to hurryinhoosier62 For This Useful Post:
Old 03-04-2022, 04:21 PM
Thanks hoosier, using those numbers, looks like boring out another 0.030” would cause issues in most of the cylinders. Thrust sides on Cyls 5 and 6 being the most affected. I was hoping to reuse the OE cast rods that came with the block, they’ve already been redone with ARP studs. I know Eagle h beams would be lighter, but if I’m springing for forged pistons/rods, it doesn’t make sense to not build a stout 455 with 9.5 or so compression and a RAIV cam. And it seems the vibe is that this block would be the weak link in that setup.
Old 03-03-2022, 03:52 PM
Some good stuff, though prices seem a touch high. Unfortunately I am on the west side of the mountains, and that’s quite a drive. Thanks for the link tho.
