Old 03-06-2022, 10:41 PM
ZeGermanHam's Avatar
Hard to imagine a fuel tank, straps, and mechanical fuel pump costing less than a bypass regulator. Perhaps you had an old mechanical fuel pump laying around, and I suppose you can sell also your EFI tank to recoup some of the cost. But I get it - you just want to go with what you know. Can't fault anyone for that. Plans can and do change on projects of this scale.
1998 BMW 328is (track rat)
Old 03-07-2022, 05:32 AM
64speed's Avatar
64speed 64speed is offline
I had the pump from original plan, it’s the Holley 8 pounder. I’m not really worried about it “keeping up” because the cam has a 6500 redline and I would never spin that thing that high plus it will never see slicks and I will never get traction so. This is a really fun driver, that’s all.
Old 03-07-2022, 05:35 AM
64speed's Avatar
Regulator was close to 225 bucks. The tank was 175 plus I had a 3/8 sending unit from original plan. Probably didn’t come out even but it worked in my head and yes the tank is for sale in the parts section.
Old 03-07-2022, 09:51 AM
Holeshot71's Avatar
Holeshot71 Holeshot71 is offline
Was the fuel pump eccentric installed when the motor was built?
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55
'72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80
Old 03-07-2022, 10:32 AM
64speed's Avatar
Yes for this very reason. Just in case. This is an amateur restoration at best BUT even though I have mental problems it made me a thinker. You won’t be able to say that I didn’t plan for every thinkable contingency 😂
Old 03-07-2022, 11:01 AM
Holeshot71's Avatar
That’s good, I was hesitant to ask lol. The car looks great. Looking forward to hearing it once it’s all together..
Old 03-07-2022, 12:38 PM
Yowza, what regulator was it? My Aeromotive bypass regulator only cost $175, and would have allowed you to keep the EFI tank and straps, etc. Did you have to buy a new mechanical fuel pump, too, or did you have one from before?
Anyway, I'm excited to see your car get some miles put on it soon. I hear the last 10% of finishing a job like this is the most tedious part.
Old 03-07-2022, 03:36 PM
grivera's Avatar
grivera grivera is offline
Like I said in post #703 https://forums.maxperformanceinc.com...postcount=703:
"If you decide to do a carb there is no reason to get rid of the EFI fuel tank. Just install a universal bypass regulator like the Aeromotive 13301 or Trickflow TFS-27001 (they are the same regulator but Trickflow saves you about $50) and run the high pressure pump with a carb. This will solve any potential fuel starvation issues assuming you use the right size fuel line. I did this with my Q-Jet prior to going with the Sniper.
https://www.summitracing.com/parts/a...iAAEgLjv_D_BwE
https://www.summitracing.com/parts/t...SABEgKBVvD_BwE
The Aeromotive 13301 is $196 and the Trick Flow is $142, fwiw
All that being said - looking forward to seeing video of the first drive!!!
Will Rivera
Old 03-07-2022, 04:07 PM
Yeah, the Aeromotive 13301 is what I have. You can find them for $142 online, too. I paid $175 at the time for mine.
