Old 03-07-2022, 04:14 PM
roger1's Avatar
roger1 roger1 is offline
So I'm guessing the signs of heat damage in the console to my donor console harness was someone staying on the starter for an extended period? Probably far beyond the factory recommended cranking time?
It wasn't horrible damage, just the factory female spades melted into the connection for the neutral switch and some shrinking back of the insulation on both switch end and plug end.
I replaced the female spades with tin plated brass double crimps, after trimming back the wire a bit, covered the crimps with shrink tubing, left the females uncovered to help dissipate any heat, so no longer a "connector" on the switch end, just the separate terminals. Just cleaned up the plug end connectors and used anti-corrosion grease.
I'm one of those people that if the engine doesn't start within about five seconds you stop and find the problem. Preferable about one second
My guess is that the connections were loose, dirty or both and caused them to heat up. Btw, starting in '69 the purple wire doesn't run to the console like it does in yours. The park/neutral switch is on the steering column and the back linkage turns the inner shaft to lock the steering wheel and also controls the P/N switch.
I bought a kit to move it back to the shifter in the console for my '69 only because I've changed the transmission to a 200-4R. The original back linkage still locks the steering wheel but I don't have to worry about if the P/N switch still would have worked since the detents for the gears aren't the same as the Turbo 400.
'69 GTO Convertible - Acquired October 2020. An all original project car. Restomod is underway PROJECT THREAD
'83 Chevy Choo Choo SS El Camino - LT1 350/4L60e, Owned for 30 Years, completed 2nd restomod in 2018 PHOTO
2019 BMW 440ix - Twin turbo I6, 8spd auto. PHOTO
'55 Chevy Bel Air Sport Coupe - Ram Jet 350 / T56 Magnum 6spd, Restomod Completed Sept. 2012, Sold Sept. 2021 PHOTO
The Following User Says Thank You to roger1 For This Useful Post:
