Old 03-23-2022, 11:59 PM
70gp 70gp is offline
Default Adding Cornering Lamps To My 70
I've had them laying here for a while now and figure it's about time to put them on. A couple questions though. My car does not have the headlamp harness with the cornering lamp wires. Is there a way to tap into my headlamp harnesses at the bulkhead connector, so I don't have to replace the whole harness ? In the upper right on the attached picture, I think I know which 2 spots the wires go to, the 2 way on the right with the dashed lines going to them.
The other question pertains to figuring out exactly where to cut the fenders to mount them. Anyone have any insight on this ? I made a template that I think is acceptable, now just have to figure out the placement of it.
Name:	Cornering lamp 3.jpg
1970 Model J GP 455HO
Old 03-24-2022, 12:58 PM
Doing a little more digging on this. Is it correct that I also have to change the turn signal switch ? Is there anything else I have to change beside the front lamp harness and the directional signal switch ? Thanks for any help !
Old 03-24-2022, 09:11 PM
Burgess's Avatar
Burgess Burgess is offline
I've had this piece of a fender from a '69 SJ hanging on a nail for 30 years, just so I could locate lights to other fenders if I ever needed to.
I made a few quick measurements, maybe this can help you locate yours. Sorry the bottom of the pics got cut off, the lower measurements are from the sharp crease at the bottom of the fender, not the edge of the metal. The 3-1/2'' distance at the front is from the point, straight back to the front edge of the cutout.
The dimensions for the cutout are to the corners, the lower front is curved, just draw imaginary lines until they meet. The upper right corner is slightly more than 90 degrees, so the rear edge is not exactly square. You might be able to use your light for reference.
Name:	cornering light hole.jpg
ID:	587086   Click image for larger version
Name:	cornering light loc.jpg
Old 03-25-2022, 02:19 AM
Scott Thelander's Avatar
fairly sure I have a nice front harness off a 70 SJ I had with side lights, still
Scott
Old 03-25-2022, 07:41 AM
comanchefirebird comanchefirebird is offline
You will need a different harness in your steering column. Will try to get you a pic this weekend
Steve
Old 03-25-2022, 04:12 PM
Thanks a lot for this info, it will be a great help !!
Old 03-25-2022, 04:33 PM
Scott
I will keep that in mind, I'm not sure which route I'm going yet. Thanks for letting me know !
Old 03-25-2022, 04:54 PM
Steve
Are you saying I will also need a new harness that the directional switch wiring plugs into at the base of the steering column ? Does that one run to the fuse box then ? Also, would you know if this harness is available anywhere ? Sorry, I'm not much of a wiring guy at all.... Thanks for your help, I'm afraid I'm gonna need it !! Lol
Old 03-25-2022, 08:29 PM
1965gp 1965gp is offline
I just saw this by chance, but when I went to pick up my GTO from the shop I noticed that they had a parts car that was a 69/70 GP and it had the cornering lamps in the fender. May have a harness if you need it.
Old 03-26-2022, 02:14 AM
OG68 OG68 is offline
IIRC there was a special turn signal switch for the Cornering Lights
https://secure.amesperf.com/qilan/De...A&web_access=Y
Old 03-26-2022, 11:21 AM
Yes, you are correct. I have ordered the turn signal switch made for the cornering lamps. It has an extra 3 wires in the plug. Now my concern is if the wiring harness that the turn signal switch plugs into at the base of the steering column would also need to be changed, or does that harness have the extra 3 wires already in it ? I appreciate your input !
Old 03-26-2022, 11:44 AM
This is very helpful information ! The worst part of this little project is that I don't know what I don't know, lol. I'm not sure if there's another harness under the dash that goes up to the base of the steering column that the directional switch plus into that also needs changing ? Or if it's just the turn signal switch and the headlamp harness in the engine compartment that needs changing ? I very much appreciate your help !! Thanks
Old 03-26-2022, 02:26 PM
The photos below were pulled from the '70 Service Manual. If you have a copy its in the Chassis Electric chapter (12)
Doesn't appear to be a separate harness..
ID:	587164   Click image for larger version
ID:	587165   Click image for larger version
ID:	587168   Click image for larger version
ID:	587169   Click image for larger version
Old 03-26-2022, 04:00 PM
I checked two dash harnesses I have out of 69 GP's. One is a SJ harness with cornering lights and the other a J without cornering lights. Both have a plug with three wires-brown,black and orange labeled A B C.
This is the plug that would go on the clip for the cornering lights.
First pic shows switch harness for cornering lights in the foreground and regular switch behind it. Second and third show the plug to use
Steve
ID:	587179   Click image for larger version
ID:	587180   Click image for larger version
Old 03-26-2022, 05:45 PM
Thank you so much for your effort. I appreciate it very much !! That makes my day that I won't have to find a different harness under the dash !
The Following User Says Thank You to 70gp For This Useful Post:
Old 03-26-2022, 06:02 PM
Steve
I am forever grateful to you for this information ! I am very happy that I don't have to goof around with changing any other harnesses under the dash. There's sure a great group of guys on here, is all I can say . Thanks again for all your efforts !!
Old 04-02-2022, 09:14 PM
Well, I ran across another hurdle over the past couple days and am posting this as an FYI to the next guy that would decide to add these cornering lights to their GP J. I made an assumption (yes, I know the saying about assume) that the '69 and '70 Grand Prix SJ's used the same headlamp harness with the cornering lamp terminals on them. I bought a used harness from a '69 SJ to use on my '70 J and when I looked closer at the harness plug that goes into the bulkhead, I noticed that one of the terminals in the plug was missing from the location it was supposed to be according to my '70 Pontiac Service Manual. Terminals used for the cornering lamp option on the '70 are in location BS & DS. The plug on the '69 harness did not even have a tab at location BS. I found a 1969 Pontiac Service Manual pdf online and found that the cornering lamp terminals were in location CT & CU on the '69 harness. A quick continuity check confirmed this, so the '69 harness is a no go. All the other connections in the plug are in a different location too. The seller was nice enough to take it back and I can get a new harness from Ames or M&H, so it's just a bump in the road. But I just am posting this to possibly save someone else the grief if they do a search on this subject.
Name:	Cornering Lamp Harness From 1969 GP SJ .jpg
ID:	587836   Click image for larger version
Name:	Cornering Lamp Bulkhead Schematic 1970.jpg
ID:	587837   Click image for larger version
Name:	Cornering Lamp Bulkhead Schematic 1969.jpg
Old 04-09-2022, 12:09 AM
The dash harness was the same with and without the cornering light option but you do need the specific turn signal switch. However, I’ve seen many non cornering light cars where the extra connector for the turn signal switch has been chopped off by the factory during install. If you run into this you can always fab a connector yourself and splice it in to the harness.
Also, for the forward lamp harness you can keep your original and simply fab two new wires (lots of Packard connector kits on eBay). Just insert them into the harness bulkhead connector in the appropriate holes (as per the shop manual) by carefully removing the seam sealer in those holes.
Extra point to watch is to sand or grind bare the inner fender surface around the bezel mounting bolts as they require body grounding to function.
Old 04-10-2022, 10:44 PM
Thank you for your helpful info. I just want to make sure that this pertains to dash harnesses on the 70 GP's specifically, if they were the same with or without the corner light option on the 70 GP ? Just want to make sure that even if they snipped the connector, that I'll at least have the wires in the dash harness to splice into. I'm a little worried that maybe just the 69's had the same dash harness ? Thanks again for everything !
Old 04-10-2022, 11:29 PM
Good point about 70 vs 69. Easy enough to check though, two ways…
First have a look at the dash harness on your car and look for the second connector with three wires right next to the main connector above the column that plugs into the main connector on the lower side of the steering column.
Secondly, if you can’t access the car just look at a 70-71 vintage MPC (factory parts catalogue) and see if they list dash harnesses with or without cornering lamps.
Funny tidbit, I’ve noticed that 68-69 GTO’s with hideaways all have the cornering lamp wires in the forward lamp harness (even on cars without cornering lamps installed) but non hideaway cars without cornering lamps do not have those wires in the forward harness. I guess they were compromising between not putting unnecessary cost into all cars and limiting part number proliferation?
