Ames Customer Satisfaction Forum Post a 'current' compliment, suggestion or issue with regard to an Ames service or product.
Old 03-28-2022, 12:44 PM
AMES-TECH's Avatar
AMES-TECH AMES-TECH is offline
Ames Tech Staff member
First let me say that I think the quality of materials is outstanding on this product but I ran into some problems on installation.
First the swagging that holds on the nut for the horizontal bolt extends into the area that sandwiches the frame mounts and has to be ground off, about 1/16".
Second, on the right hand mount I received the bolt holes were no where close to lining up with the block holes. While the holes are spaced the correct distance from each other, the pair of them are not centered properly on the tabs that hold the horizontal bolt.
See picture below.
I solved the issue by slotting the holes with a milling machine. But that leaves the metal surrounding the bolt hole a bit thin on the rear hole.
In general, very happy with the construction of these new mounts ... but the manufacturer needs to adjust the position of those holes about 3/16" for the right side to work. Not sure if it's all of them, or just the set that I got.
Thanks.
Dataway, thank you for bringing this to our attention! We have seen some of the nuts protrude too far into the frame bracket opening, some worse than others. The mounting holes to the block we have not seen until now. I grabbed a couple pairs off the shelf to try on one of our engine blocks here in the office. The holes left plenty of room for both bolts to be easily started. The fact that yours were so far off is very interesting; I'm hoping this is an isolated incident. Please feel free to email me at [email protected] with more pics and info. See the pics below:
ID:	587335   Click image for larger version
ID:	587336   Click image for larger version
ID:	587337   Click image for larger version
ID:	587338   Click image for larger version
[/SIGPIC]
The Following User Says Thank You to AMES-TECH For This Useful Post:
Smilies are Off
