Old 04-16-2022, 11:45 PM
GtoFM's Avatar
GtoFM GtoFM is offline
Default '64 power steering conversion notched fan
I am converting my stock '64 389 GTO with a clutched fan to power steering. Do I need to change to a notched fan to clear the PS mounting bolts?
Old 04-17-2022, 07:30 AM
Cardo's Avatar
Cardo Cardo is offline
No you shouldn't need to. The notched fans were only on 1965 models with factory air conditioning. The notch is to clear the shaft / center of the pulley on the power steering pump, those units had a different power steering pulley. If you have any interference issues, something else is wrong, most likely one of the parts you used.
Old 04-17-2022, 03:07 PM
tallrandyb's Avatar
tallrandyb tallrandyb is offline
And I have a 65 with factory AC and don't have the notch but also clear the PS pump, its close but still enough room to not be concerned. This is on a 66 block but I assume the mounting/alignment is the same.
Old 04-17-2022, 10:26 PM
GtoFM's Avatar
Thanks for the info!
