Old 05-03-2022, 08:47 PM
Mark66 Mark66 is offline
Default 66 Pontiac fuel line, pump to fuel/vapor separator filter
Does anyone sell a metal fuel line for 1966 Pontiacs (for a 4 bbl, not 2 bbl or tri power) that runs from the fuel pump to the fuel and vapor separator filter that sits just above the water pump? The original line was rubber and I would like to increase my safety margin. The obvious suppliers do not carry this item – I could bend it myself but would prefer not to if someone else has done a professional job.
Strange that the vapor return line running out of the fuel and vapor separator filter to the main to the main fuel tank vapor return line is metal – but the fuel line into the fuel and vapor separator is not.
Old 08-30-2022, 02:46 PM
70ra455's Avatar
70ra455 70ra455 is offline
Bend one. Not hard
1970 GTO Convertible 455 Ram Air M-21, Atoll/Blue/Black, Hood Tach, 3:31 12-Bolt Posi, A/C, Console
1966 Grand Prix 421 Tripower 4spd, Marina Turquoise/Turquoise, a/c, console, posi, reverb. pa, pb, ps, remote mirror, mats
2010 Dodge Challenger R/T Classic, 6spd Hemi, Detonator Yellow, black stripe, black leather
Old 09-01-2022, 11:17 AM
pfilean's Avatar
pfilean pfilean is offline
Does seem strange but parts book seems to show fuel hose both in and out of filter.
Old 09-01-2022, 05:07 PM
70ra455's Avatar
That's correct
Old 09-03-2022, 06:19 AM
Heybuck's Avatar
Heybuck Heybuck is offline
I replaced my fuel lines just over 20 years ago. I had them made by Classic Tube if I recall correctly. No idea if they still sell them but worth an ask.
To laugh at men of sense is the privilege of fools.
Old 09-04-2022, 06:30 PM
I have four 1966 Big Pontiacs all with AC. They all use a rubber hose from the pump to the "fuel and vapor separator filter" and a steel line from the filter back to the return line to fuel tank. Page C-448 of the Pontiac Chassis Parts Catalog (effective October 1, 1966) uses the term "pipe" when referring to the filter to vapor return line connector (actually a steel line from the filter to a 7 3/4" x 1/4" ID hose which then connects to the steel vapor return line which runs to the fuel tank). The illustration also shows the fuel line from the pump to the filter but does not give it a part number, presumably because it is just a rubber hose.
The engineers must have had a reason for using a steel line for the section of the vapor return line that snakes down the front of the engine - perhaps due to the proximity of the belts.
If I want a steel line from the fuel pump to the "fuel and vapor separator filter" I will probably have to bend it myself as I have not found one commercially available - but I will check with Classic Tube.
