Old 05-21-2022, 08:09 PM
MUSLCAH MUSLCAH is offline
Default Oil light in dash Question
1964 GP 389 4 bbl ….dash oil light comes on….and dip stick says Full. Can these sending units act up ? Thanks
Old 05-21-2022, 08:29 PM
64speed's Avatar
64speed 64speed is offline
Yes it could be bad sender or no oil pressure. Check it with a known good gauge
Old 05-21-2022, 08:53 PM
roger1's Avatar
roger1 roger1 is offline
https://www.amazon.com/JIFETOR-Press...3180679&sr=8-8
'69 GTO Convertible - Acquired October 2020. An all original project car. Restomod is underway PROJECT THREAD
'83 Chevy Choo Choo SS El Camino - LT1 350/4L60e, Owned for 30 Years, completed 2nd restomod in 2018 PHOTO
2019 BMW 440ix - Twin turbo I6, 8spd auto. PHOTO
'55 Chevy Bel Air Sport Coupe - Ram Jet 350 / T56 Magnum 6spd, Restomod Completed Sept. 2012, Sold Sept. 2021 PHOTO
Old 05-22-2022, 06:29 AM
25stevem's Avatar
25stevem 25stevem is offline
When does the oil light come on, at hot idle and then go off at around 2000 rpm?
I do stuff for reasons.
Old 05-22-2022, 07:31 AM
theamcguy's Avatar
theamcguy theamcguy is offline
The oil light measures oil pressure not the oil level. In short the sending unit can go bad and the light can come on especially during hot idle. It could also be low oil pressure due to a worn pump or worn bearings. The only sure way to know is to temporarily plumb in a gauge and check the pressure.
Bill Strobel
Owner Independent Towing
1965 GTO Nightwatch Blue/Aqua
2005 GTO Quick Silver/Red
Fayetteville, NC
Do It Right or Don't Do It All
Old 05-22-2022, 08:16 AM
25stevem's Avatar
X2 with post 5!
Also if with the motor cold and you crank the motor and the light goes off once the motor starts up then there’s a very high percentage that the sender is still good when the motor is fully up to temp, as in 5 minutes of driving around in temps above 60.
Old 05-22-2022, 02:27 PM
So I started up the GP….and the light came on after 25 seconds of idle time. Then i let it warmed up at idle ,in park, for 5 minutes. The light stayed on …BUT WHEN I JABBED THE GAS PEDAL….the light went out for a second ,then came back on. I change the oil and filter every spring…but havent changed it yet. Had this car for 5 years and this is the first time this light has come on. Maybe an oil and filter change will do the trick. Probcably 1000 miles driven last year
Old 05-22-2022, 02:53 PM
grandam1979 grandam1979 is online now
If you hold the throttle at 1000-1500 does the light go out ?
Old 05-22-2022, 03:31 PM
25stevem's Avatar
It sounds like to like the oil pump check ball is being kept unseated by some crap from the bottom of the pan, non the less I would not run the motor any longer until I had a cheap mechanical gauge hooked up to the where the sender currently is to confirm what may or may not be going on with the pressure.
Old 05-22-2022, 03:37 PM
Ok …thanks for the info
Old 05-23-2022, 03:59 AM
lust4speed's Avatar
The sender is set to turn the light on if pressure drops below about 4.5 pounds. If the light is on and the sender is good, the actual pressure is below that amount but you just won't know how low it is until you get a gauge plumbed in.
Mick Batson
Old 05-23-2022, 08:47 AM
Could oil over fill …cause this problem. .?
Old 05-23-2022, 11:40 AM
25stevem's Avatar
100% no on that!
Old 05-23-2022, 01:40 PM
Thank You....got a guage coming...
Old 05-30-2022, 05:44 PM
We have oil pressure at a hot idle ..YIPPIE !!!!! So the sending unit was bad. I all my years …this is the first sending unit that gone bad…lol And many thanks for those of you that gave me the info on that guage . Thank You
The Following User Says Thank You to MUSLCAH For This Useful Post:
Old 05-30-2022, 05:59 PM
25stevem's Avatar
Yup , your golden!
Old 05-30-2022, 09:48 PM
roger1's Avatar
Great!
Money well spent for that tool.
Old 05-31-2022, 08:52 AM
Originally Posted by roger1 View Post
Great!
For sure !…and when I ordered the guage….it was here THE NEXT DAY !
