Old 06-06-2022, 01:17 PM
64speed's Avatar
64speed 64speed is offline
It’s at 15
Old 06-06-2022, 01:50 PM
It might be too rich at idle then if it's getting hotter.
Old 06-06-2022, 02:05 PM
64speed's Avatar
I think I could go in another 1/4 turn. It doesnt make much difference in vacuum so do you think its worth doing?
Old 06-06-2022, 02:50 PM
64speed's Avatar
Rich or lean will make it hotter?
Old 06-06-2022, 06:35 PM
64speed's Avatar
My vision is not good enough to see the timing mark so I have to get help but turning the cap a little at a time produces a crappy running engine other than exactly where it is. It is slow to creep like I said but it creeps. Turning on the heater instantly drops it 15/20 degrees from wherever it is and holds it there. I am getting a bigger mechanical fan cause I did the paper test and it will hold a sheet against the radiator but not with the force I feel it should.
Old 06-06-2022, 01:59 PM
grivera's Avatar
grivera grivera is offline
Originally Posted by 64speed View Post
It’s at 15
15 mechanical. Add 10 via manifold vacuum and see if it cools down.
Will Rivera
