Old 06-04-2022, 02:38 PM
POS Racing POS Racing is offline
Default 350 Pontiac almost in the 10s!
Had the Ventura at Mason Dixon today for the Outlaw Pontiac race. Best of [email protected] DA. Converter is still too tight but we are sneaking up on 10s and I am sure we will be there this fall.
73 Ventura 3450lbs
350P 580hp/520tq on pump gas
.030 over 10.7comp
Hand ported KRE heads fitted to the 350 bores
.670 lift solid roller
Heavily ported PP Crosswind dual plane
750 Brawler
Hooker 1 3/4 headers
TH350
Reverse manual valve body
4000 stall ATI converter
8.5 10 bolt
3.90 gears
33 spline Moser axles and spool
Caltracs with split monos
QA1 shocks at all 4 corners
Total street car but was run with no exhaust today.
10 seconds here we come!!
Home of the 350 Pontiac that KICKED FULPER'S ASS!
The Following 3 Users Say Thank You to POS Racing For This Useful Post:
Old 06-04-2022, 02:52 PM
carcrazy carcrazy is offline
Knocking on the door! It will happen!!.
Old 06-04-2022, 03:32 PM
slowbird's Avatar
slowbird slowbird is offline
Nice!
Old 06-04-2022, 03:56 PM
hojs69's Avatar
hojs69 hojs69 is offline
Location: Pacific NW by way of Detroit, Tampa, San Diego
Good to see the 350P being done.
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
The Following User Says Thank You to hojs69 For This Useful Post:
Old 06-04-2022, 04:08 PM
ponchonlefty ponchonlefty is offline
go 350 go !
Old 06-04-2022, 04:50 PM
AG's Avatar
AG AG is offline
Very impressive. The mph looks a little low for the time.
Old 06-04-2022, 05:53 PM
ponjohn's Avatar
ponjohn ponjohn is offline
I think its spot on.
Old 06-04-2022, 08:34 PM
Still tuning. Only 2nd time to the track🙂
The Following User Says Thank You to POS Racing For This Useful Post:
Old 06-04-2022, 09:13 PM
Scott Stoneburg's Avatar
Congrats! Definitely a well thought out 350. Nice job. I'll be watching for the updates. I'm sure you will get there.
Old 06-05-2022, 01:37 AM
Dragncar Dragncar is offline
I run a 10.80 with that MPH. He is doing fine.
Get the 60' down and you are in the 10s.
Old 06-05-2022, 03:07 AM
Impressive showing for the Rodney Dangerfield engine of the Pontiac family. Easily a 10sec car with a better 60' as Dcar said..
The Following User Says Thank You to Scott Roberts For This Useful Post:
Old 06-06-2022, 08:08 AM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
agree very nice combo. what rods and rpm are you spinning it to?
Old 06-07-2022, 07:42 AM
Eagle H-beams. Shifting at 6400. Currently through the traps at about 6200
Old 06-07-2022, 10:00 AM
Stan Weiss's Avatar
Why are you shifting so low? Your peak HP is at 6500. I think you are leaving .1 to .15 et decrease on the table by not shifting at around 6900.
Stan
Pontiac Pump Gas List
Old 06-07-2022, 10:16 AM
Stan
We went back to the PP dual plane....its .07 quicker in 60ft than the Victor. With that manifold peak hp was 6200. I still agree it wants shifted higher....this is only our 2nd time out with it and it got put right into bracket duty after one T&T day. Lots of tuning and tweaking to do. Lining up another converter to try also. Its deadly consistent already. Firm believer in efficiency=consistency.
Old 06-07-2022, 03:48 PM
You engine might like a smaller single plane intake. T2 or Tomahawk. The Warrior was designed for a 366ci engine, but hard to find and expensive.
The Victor is simply too large a intake for a 350. But you have a race engine with a big .670 cam and that usually means the right single plane intake.
Tomahawks are cheap and work well.
Old 06-07-2022, 04:54 PM
You may be correct but my dual plane isnt really normal. LOL. Within 15hp of the Victor at peak and a MUCH better torque curve than any of the single planes. Destroyed an out of the box RPM(it was RAIV matched) by 30+hp and 10lbs. I have a ton of time on the flow bench getting the runners equaled both in sq/in and flow as best as possible.🙂
ID:	592361   Click image for larger version
The Following 2 Users Say Thank You to POS Racing For This Useful Post:
Old 06-07-2022, 07:31 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Good job! Nice build.
Go fast, see Elvis!
Old 06-07-2022, 07:50 PM
BILL BOWMAN1's Avatar
Sweet motor! Wanting to do similar.
Old 06-07-2022, 09:58 PM
Sounds like you have this thing dialed in.
I threw away a perfect 1969 350 std bore block with the factory valve reliefs years ago. Even those things are going for some money these days.
