#361
Old 03-05-2022, 05:40 PM
SD455DJ SD455DJ is online now
Originally Posted by unruhjonny View Post
it's one of those pieces that can easily be missed upon reassembly.
We'll make sure it's there when we pull the insert and cluster to swap out hte printed circuit.
Dennis
  #362
Old 03-06-2022, 10:04 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
here is a well lit picture, the right end of the Z needs to be under the blue gauge divider directly against the metal cluster housing. Might not be the problem but it caused me a couple of odd electrical gremlins.
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
The Following User Says Thank You to RicksGTO For This Useful Post:
  #363
Old 03-10-2022, 07:16 PM
Default All is right with the world again!
All the gauges are working fine now and we figured out the culprit was old oxidized connections on the original 52 year old dash harness. Unplugging and replugging important connectors several times must have cleaned them off enough to establish better connections again. The headlight switch was also complicit causing the weird glowing lights and spastic gauge movements and reestablishing a good connection seemed to fix those issues too. It's always the simple things that can stump you, but sticking with it and walking away to clear your head can work wonders. Thanks for everyone's help and comments.
Dennis
ID:	585853   Click image for larger version
  #364
Old 03-17-2022, 08:22 PM
Checked the bulbs in the new dash gauges & tach, and they are all working. The cell phone doesn't take the best pictures when in really dark conditions.
Dennis
ID:	586487   Click image for larger version
  #365
Old 03-17-2022, 11:45 PM
unruhjonny's Avatar
I remember driving my Firebird on the highway at night;
I loved the glow of the gauges.
1970 Formula 400
  #366
Old 03-18-2022, 09:34 AM
Yes, me too! They are bright enough with new standard filament bulbs...not LED's.
Dennis
  #367
Old 06-11-2022, 09:00 AM
Finally got the 'CL' 14x7 steel wheels from Steve Johns (Commanche) this past Thursday. We've been trying to get this deal done since 2019 when the borders shut down. So, almost 3 years later, we finally finished the deal. The wheels came off a base Firebird 350 originally from southern Californian then Arizona for most of it's life and are all dated 1/16/70 (my spare CL is 4/09/70). The wheels are original Castilian Bronze as was the Firebirds body color too, and was equipped with the optional trim rings which left only minor scratches due to the lack of moisture and minimal corrosion. The CB paint looks amazing still as does the black backsides. I haven't cleaned them up yet, but will do that before I paint them Lucerne Blue. I'm going to leave the backsides in their original black paint. Thanks Steve for saving them for me!
Dennis
ID:	592614   Click image for larger version
ID:	592615   Click image for larger version
Name:	Spare Tire 1.jpg
  #368
Old 06-11-2022, 10:46 AM
Ramairnacho Ramairnacho is offline
I.too have CL 14 x 7 I have 2 or 3 2 22 dated and 2 later April CL wheels. I misplaced 2 2 22 dated and looking fir 1 2 22 .Does he have 1 a spare tire would be nice too and a trunk mat
  #369
Old 06-11-2022, 11:32 AM
Nope...no spare unfortunately, I just got the 4 wheels, but I have the original 'CL' spare, so don't need one. I'm not concerned about finding matching dates as it was hard enough finding a complete set of 'CL' wheels. I have the trunk mat in mine already (Ames repro).
Looks like you are in good shape wheel-wise...
Dennis
  #370
Old 06-11-2022, 07:57 PM
unruhjonny's Avatar
interesting;
Almost every CL wheel I can recall seeing was a Motor Wheel stamping;
These are Kelsey Hayes.
The set of four that I bought (undated) were Norris wheels, but considering how hard they seem to be to find, I was happy to get them.
My fifth (the first one I got) was a March date too iirc.
1970 Formula 400
  #371
Old 06-11-2022, 11:25 PM
An you explain in detail or show me difference of both cl wheel manufacturers
  #372
Old 06-11-2022, 11:27 PM
Sd455dj
Do they make new or repop spare tire for space saver and is cl.corrrct rim. I might have 1 or 2 extra cl rims i.could use.my jack is in my dad's garage I hope
  #373
Old 06-12-2022, 07:51 AM
I added this CL wheel to my web page:
Rally Wheel Decode
The Following 2 Users Say Thank You to johnta1 For This Useful Post:
  #374
Old 06-12-2022, 08:09 AM
comanchefirebird comanchefirebird is offline
You are most welcome Dennis. Sorry that it took so long to get them to you!
I'm looking forward to seeing them on your Formula
Steve
Dennis
The Following User Says Thank You to comanchefirebird For This Useful Post:
  #375
Old 06-12-2022, 09:36 AM
Sd455dj
Ramairnacho, Not that I know of. I do have a space saver spare in my '70 Judge, so I'll check the stampings out the next time I pull it out of the garage...it's buried!
Dennis
Name:	70 RAIV Judge 1.jpg
  #376
Old 06-12-2022, 10:02 AM
Thanks Dennis, my dad ran a full spare tire I believe
  #377
Old 06-12-2022, 10:09 AM
unruhjonny's Avatar
the two space saver spares I have here are both 15";
they are both 1979 wheels coded RF
1970 Formula 400
  #378
Old 06-12-2022, 11:13 AM
Like this ('78 TA space-saver spare)?
Dennis
ID:	592682   Click image for larger version
  #379
Old 06-12-2022, 11:33 AM
unruhjonny's Avatar
yes.
one has a crack on one spot of the rubber sidewall;
It appears as though it may have been used several times.
The other one looks very nice.
IIRC the older ones had two valve stems, or one funny one - these only have one conventional valve stem.
1970 Formula 400
  #380
Old 06-12-2022, 04:55 PM
So.original was a 14 but they don't make space saver tire any more? And next best thing is the 15 inch? Hmm now I see why dad had a actual extra tire in trunk. Lol
