Here is an updated list of what is left:
Felpro 1233 intake gaskets $10 (Super Duty port size) CB748-P Rod Bearings, std. $60 Felpro 1627 thick valve cover gaskets $15 Timing cover very good shape $70 Crane 290H Fireball cam with matching lifters (used but excellent) $75 Sealed Power piston rings, part number E-299X, 4.12 standard bore, $40.00.
CB748-P Rod Bearings, std. $60 Felpro 1627 thick valve cover gaskets $15 Sealed Power piston rings, part number E-299X, 4.12 standard bore, $40.00. $100 shipped for above? 02822 zip
1968 firebird cameo white on red 400 4 speed 1969 carousel red firebird 455, richmond 5 speed 1964 gto pump gas, 505 IA2 EHeads, EFI, 92 mm turbo ice cream getter in process now.... 1970 lemans hardtop, gto clone Atoll Blue 1972 Maverick powered by 2004 gto ls1 and t56 6 speed, 8.8, fox strut front end, wifes car |
