Old 07-14-2022, 01:27 PM
Tandyman Tandyman is offline
I see the rectangular slot in 17 but I am talking about the gouge beside it . That looks like it was made by a drill coming up from the bottom of the main body to my old eyes.
Also , That would mean that when the op sprayed clean into it , the spray came out the hole in the bottom of the main body that lines up with the check ball and that is why Op asked if the check ball should be JB welded in post 22 . If it came out someplace else then I guess my speculations are wrong .
Glenn
Old 07-14-2022, 02:43 PM
X72GPX's Avatar
X72GPX X72GPX is offline
Send a message via AIM to X72GPX
My secondary power valve is plugged, could fuel get into that well in the main body causing me to lose secondary idle screw response? Also reposting pics here. Not sure I mentioned its a vacuum secondary and you are correct list 80497.
Glenn
ID:	594301   Click image for larger version
ID:	594302   Click image for larger version
