Old 07-25-2022, 12:51 PM
Ogre's Avatar
Ogre Ogre is online now
I forgot to mention when I started this thread, that this is NOT a concourse restoration. This is probably not even a "keeper." The '72 hard top on my rotisserie is the one I want to finish and keep. That info will hopefully help y'all give me advice. I definitely do not wish to take it the boat ramp, and see how far it can go before it goes really deep. But these old gals are getting rarer and I'd like to get this one back on the road (in roadworthy condition). All of the mechanicals a great, interior carpet/reupholstering done, brakes, engine, tranny, etc. are all good.
Bumper is off, so a few more shots of the damage below. I am back to using as much original metal as possible, but after digging into the bondo, I will need to go to at least the first ridge and the second will be a little better.
I would almost bet that something will torque after I cut, so I am planning on bracing inside, and using tie down straps outside (around the quarters and over the trunk opening) to make sure everything stays in place. Speaking of trunk opening ... from the top by the rear window it is 52 1/8" - 52 1/4" wide, and most of the way all the way down to the rear lip. After the downturn to the rear bottom opening it is 51 3/4" ... or 1/2" narrower. So I need to take that into consideration as I put the new metal in.
As always advice is welcome ... Next step jack it up and remove the fuel tank ... I have no desire to be cutting close to a fuel tank with gas in it !!
The last pic below is the replacement piece showing how far the "water drip" part should stick out.
Ogre
ID:	594957   Click image for larger version
ID:	594958   Click image for larger version
ID:	594955   Click image for larger version
ID:	594956   Click image for larger version
“Man will ultimately be governed by God or by tyrants.”
-- Benjamin Franklin
- (1706-1790) US Founding Father
Old 07-25-2022, 02:12 PM
ponchonlefty ponchonlefty is offline
Ogre
yeah, i can see better what your dealing with. looks like alot of welding and grinding. sounds like you have a good plan. i would not cut on the line. give yourself some room to adjust. maybe 1 inch around so the replacement overlaps. then fine tune from there. take your time you will be successful .
Old 07-26-2022, 09:22 AM
Ogre's Avatar
Thanks lefty. I appreciate the feedback.
Ogre
Old 07-28-2022, 10:37 AM
Ogre's Avatar
Exclamation WHAT ?
BTW, you would think a more discerning car purchaser (me) would have been a little suspect of the damage extent when he/she replaced this fuel tank in 2006. LOL
Probably a good indication of some necessary body work. Of course, my primary efforts have been on the engine/brakes/trans and other mechanicals. Just got started on the stripping/body work/priming part of this project.
Ogre
ID:	595108   Click image for larger version
ID:	595109   Click image for larger version
Old 07-28-2022, 02:39 PM
Ogre
it happens to all of us. these old cars get repaired in interesting ways over time.
