Old 07-26-2022, 08:03 AM
amcmike's Avatar
amcmike amcmike is offline
Originally Posted by GTOKIDRH View Post
So correct me if I'm wrong. The LS engines before DI were mostly if not all in the 10+ CR range. I understand this was largely due to the use of aluminum as well as the heart shaped combustion chamber with a centrally positioned spark plug tip. Yes DI helps immensely.
It's a bit complicated, but I'll try to simplify.
The GENIII passenger vehicles (Corvette, Firebird, etc.) were in the low-mid 10s with aluminum block/heads premium. The small engine trucks 4.8/5.3 were mid-9s, the exception was the 5.3L HO which used an aluminum block and 9.9:1. The 6.0 LQ4 was only 9:1 but was meant for HD trucks that weighed more and would be used for heavier loads and 87 octane. There was a 6.0L LQ9 which was a 10:1 variant of the LQ4 but was used in Escalades and required premium.
The GENIV LS (debuting with the LS2) were still PFI, and saw a bump in compression with passenger cars adding about 1/2 point. For the GENIV trucks, the iron blocks (and some aluminum) were typically 9.5:1, but often had VVT which bumped up the dynamic compression below 3500rpm. Some larger aluminum blocks (like the L92) were as high as 10.5:1 but recommended premium.
With the GENV having DI, compression even with VVT, is typically 11:1 on trucks, and higher for passenger cars (but with premium recommended). And we haven't even talked about Super Charged cars, but the LT4 runs 10:1 with 9.4 lbs of boost.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
The Following User Says Thank You to amcmike For This Useful Post:
Old 07-26-2022, 08:18 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
One can’t talk about modern engine specs as a reference to old car building without realizing the fast and powerful computers running them.
